SpectatorRacing | MSD Opti installed | ||
Now that the nightmare is over I can post some pics of the MSD opti. Although with the coil issue I'm not nearly as excited about having this part on my car as i was about 3 weeks ago.
Anyway, here she is...time will tell if it's a better piece that OEM. [IMG]http://i31.photobucket.com/albums/c380/jcisler/MSDOptispark003.jpg[/IMG] [IMG]http://i31.photobucket.com/albums/c380/jcisler/MSDOptispark004.jpg[/IMG] |
Posted on: 2008/5/24 15:42
aka Scaryfast |
Notorious | Re: MSD Opti installed | ||
What was the problem with the coil? I musta' missed that.
Posted on: 2008/5/24 15:45
I hate sporks... |
pianoguy | Re: MSD Opti installed | ||
I installed one this spring, too, along with a coil - been happy with them so far. It certainly appears to be a stouter piece than the OEM.
Posted on: 2008/5/24 15:51
SpectatorRacing | Re: MSD Opti installed | ||
The coil was bad out of the box, which caused my month long debacle trying to find out why the car wouldn't start.
Posted on: 2008/5/24 16:07
aka Scaryfast |
bogus | Re: MSD Opti installed | ||
wow. bad coils will do that... sucks.
hopefully, MSD was quick to cover that. I would advise, tho, if you have issues with the coil, that the oem LT4 unit is pretty nice. |
Posted on: 2008/5/24 17:36
mrvette | Re: MSD Opti installed | ||
I'm getting ready to install the MSD but the factory shorted me some parts that I have to wait on. I have a 92 and understand the plug on the opti won't match the stock plug on the car. How do you handle that part of the installation?
Posted on: 2008/5/25 1:22
CasetheCorvetteman | Re: MSD Opti installed | ||
http://www.msdignition.com/pdf/8381_frm27275.pdf
http://www.msdignition.com/pdf/83811_frm27523.pdf There is both lots of instructions mate ![]() I would say it will include something about the 92 connector, i dont know. |
Posted on: 2008/5/25 1:53
BillH | Re: MSD Opti installed | ||
I don't know if the factory changed the instructions since I installed my MSD but, hear's the wiring, it's easy to do.
Here's the wire connections: 92 LT1 MSD black/red(stripe) to brown/yellow - low resolution purple/white to brown/orange - hi res yellow to red - 12 volt black/pink to red/green - ground The 5th wire in the LT1 harness is a ground/shielding wire. It's not needed on the MSD Opti. It doesn't connect to anything on the GM Opti either, just wraped around the other 4 wires for shielding. |
Posted on: 2008/5/25 13:26
There is an Optispark "test connector" along the heads / fuel rail on the passenger side of the motor. The plug that is different between the newer and older cars is the harness from that connector to the opti itself.
The MSD part comes with that part of the harness, so it should plug right into the connector along the fuel rail. It did on my '93. EDIT: just found out the '92 is different than my car. Will leave post above for others reading. |
Posted on: 2008/5/25 13:54
aka Scaryfast |
I meant to call MSD but didn't get there. It's been a frenzy of activity getting the car back together for a track day tomorrow. If I didn't need coffee I'd be out there right now and not here... I sent it back to Summit, I'll call MSD Tuesday. I am planning to see what they'll do for me since I bought $900 of parts (Opti, 6AL box, coil, custom harness) from them unecessarily. |
Posted on: 2008/5/25 13:56
aka Scaryfast |
The 92 has a different connector there instead of the 4 pin on the 93-96. |
Posted on: 2008/5/25 15:01
Ahhh...gotcha. Learned something today. |
Posted on: 2008/5/25 15:07
aka Scaryfast |
