200 user(s) are online (118 user(s) are browsing Forums)
94z07 Changing ZF fluid tech article PDF
94 Posts
One addition in the "Parts Sources" box could be the part number for replacement drain/fill plugs.
The GM part number is 10140673. They cost $10 to $20 each depending upon the dealer.
It seems the BMW aftermarket have made replacement plugs too that look like they will fit but I have no direct knowledge of them.
IMHO the perfect plug would be a male 17mm hex with a square machined into the center to receive a 1/4" drive tool. Then one could install them with the 1/4" ratchet and remove them with a 17mm box-end wrench.
Posted on: 2008/7/2 13:57
Business makes progress. Fortune passes everywhere.
Jeffvette Re: Changing ZF fluid tech article PDF
I sell the plugs for 10.50, have them on hand for fubar'd drain plugs when servicing.
Posted on: 2008/7/3 1:00
bogus Re: Changing ZF fluid tech article PDF
I'll take one!
Gee... Mine is already fubar'd.
Posted on: 2008/7/3 1:07
Andy, give me a shout....
Posted on: 2008/7/3 1:54
done!
Posted on: 2008/7/3 14:42
CentralCoaster Re: Changing ZF fluid tech article PDF
Here's an idea, bottom the car out enough times that the drain plug is semi-mangled, then you'll have to literally tap the 17mm hex into it with a hammer. Makes removal easier! That drainplug is the lowest part on my car.
Posted on: 2008/7/3 14:43
my exhaust is a touch lower, I think.
Posted on: 2008/7/3 14:47
BrianCunningham Re: Changing ZF fluid tech article PDF
I hope the article points out that you want to remove the fill plug before the drain plug.
Nothing like getting the drain plug out, but not the latter
Posted on: 2008/7/3 20:26
I am about 99% sure it does.
Posted on: 2008/7/3 20:47
