94z07 | Changing ZF fluid tech article PDF | ||
One addition in the "Parts Sources" box could be the part number for replacement drain/fill plugs.
The GM part number is 10140673. They cost $10 to $20 each depending upon the dealer. --- It seems the BMW aftermarket have made replacement plugs too that look like they will fit but I have no direct knowledge of them. IMHO the perfect plug would be a male 17mm hex with a square machined into the center to receive a 1/4" drive tool. Then one could install them with the 1/4" ratchet and remove them with a 17mm box-end wrench. |
Posted on: 2008/7/2 13:57
Business makes progress. Fortune passes everywhere. |
Jeffvette | Re: Changing ZF fluid tech article PDF | ||
I sell the plugs for 10.50, have them on hand for fubar'd drain plugs when servicing.
Posted on: 2008/7/3 1:00
bogus | Re: Changing ZF fluid tech article PDF | ||
I'll take one!
Gee... Mine is already fubar'd. |
Posted on: 2008/7/3 1:07
Andy, give me a shout....
Posted on: 2008/7/3 1:54
done!
Posted on: 2008/7/3 14:42
CentralCoaster | Re: Changing ZF fluid tech article PDF | ||
Here's an idea, bottom the car out enough times that the drain plug is semi-mangled, then you'll have to literally tap the 17mm hex into it with a hammer. Makes removal easier! That drainplug is the lowest part on my car.
Posted on: 2008/7/3 14:43
my exhaust is a touch lower, I think.
Posted on: 2008/7/3 14:47
BrianCunningham | Re: Changing ZF fluid tech article PDF | ||
I hope the article points out that you want to remove the fill plug before the drain plug.
Nothing like getting the drain plug out, but not the latter |
Posted on: 2008/7/3 20:26
I am about 99% sure it does.
Posted on: 2008/7/3 20:47
