126 user(s) are online (75 user(s) are browsing Forums)
1963 through 1967 Corvette.
Ozzy Supercharger question??
4 Posts
I know that procharger makes a kit for lt1 corvettes, but will the tpi supercharger work if i take out my AC compressor??????
92 vette lt1
Posted on: 2006/10/5 0:12
CasetheCorvetteman RE:Supercharger question??
Not as a direct bolt on it wouldnt. You would need to make up a new bracket umongst other things
Posted on: 2006/10/5 7:20
red_johnny RE:Supercharger question??
You can make almost anything work but its all about how much time and money your willing to throw at it. Somethings require alot of custom building.
Posted on: 2006/10/6 1:02
Ozzy RE:Supercharger question??
4 Posts
Thanks guys .
Posted on: 2006/10/6 4:01
No Problem and BTW, check out off topic. There are tons of funny posts there The arcade area is fun to maybe you can beat some of the high scores :tongue:
Posted on: 2006/10/6 13:29
hulagan808 Re: Supercharger question??
hawaii, maui
58 Posts
the tpi procharger is designed to remount the alt. and if the pwr steering is the same as the lt1 or just use an l98 pump use a delete pulley for the tpi alt. relocation, I don't see how this would be so hard to pull off if one was super cheap and available or free I would try. sounds kinda fun. Aloha
Posted on: 2008/6/30 20:35
88 vert, gen 7, superram, blah blah blah for days
anesthes Re: Supercharger question??
Boston, MA
My alternator is on my passenger side, and the supercharger on the driver side. Running the alternator backwards is lame. Some would say deleting AC is equally as lame, but whatever.
If you actually want to do the install, let me know and I'll give you some tech input. I've been running blowers for about 10 years now and have had a lot of time into numerous swaps.
The C4 is kind of a crappy platform for a blower due to space, but I think I've got a somewhat decent working combo.
http://www.youtube.com/watch?v=JXDAg0vPe2A
I've actually redone things a few times since this video.
I removed the spring tensioner, running only 1 idler with re-routed belt so I get almost 300* of belt wrap on the blower pulley. (so I don't have to run crazy tension).
-- Joe
Posted on: 2008/7/1 12:40
BrianCunningham Re: Supercharger question??
The vortec kit I bought is designed with a head unit that runs backwards so it can be mounted on the passenger side since all the accesories are on the drivers side.
old installation
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/BayStateCorvetteClub/members/Brian%20Cunningham/blower%20build/enginecompartment.jpg[/IMG]
Posted on: 2008/7/2 16:49
Boston, MA
I wish I had a reverse rotation blower and bracket. I could have plumbed the intake forward instead of the air cleaner over the headers.
-- Joe
Posted on: 2008/7/2 17:16
Here's the rather large regular rotation blower that the owners upgraded to.
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/Corvette/supercharger/engine4.jpg[/IMG]
Posted on: 2008/7/2 23:18
CentralCoaster Re: Supercharger question??
Brian, where's you're intake duct at? Looks tight in there.
Posted on: 2008/7/2 23:46
Here's the ductwork
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/BayStateCorvetteClub/members/Brian%20Cunningham/blower%20build/Picture006.jpg[/IMG]
It will wind down under the headlight where the stock radiator overflow is.
MAF goes between the ducts and the air filter.
Very similar to this ProCharger setup
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/Corvette/supercharger/Air20filter.jpg[/IMG]
Posted on: 2008/7/3 16:40
