pianoguy | Sound deadening seems to be worthwhile | ||
I got my car buttoned up this morning after putting in some Xtreme Dynamat. I had found it on amazon.com a while back, I think it cost me about $140 for a 36 square foot kit and a door kit. The stuff is pretty easy to work with. I didn't attempt to cover every square inch of the car - I did the floors, doors, bulkhead behind the seats and most of the rear wheel wells - I have enough left to do the console, didn't feel like ripping that all out right now. I'll be ripping apart the interior again someday to do install a new sound system, so can add more later if need be. Anyway, I took it for a quick spin, and it seemed quieter and more solid - I was finally able to isolate a little squeak that had bugged me for a while, but could never figure out where it was coming from above the din. The funnest part of the job was getting a bunch of little cuts on my hands, and then wiping down panels with denatured alcohol before applying the deadener. I never quite remember to wear gloves at the right time
Posted on: 2008/7/20 15:05
Matatk | Re: Sound deadening seems to be worthwhile | ||
Awesome - glad you got it - did the weather cool off for ya?
Matthew |
Posted on: 2008/7/20 18:38
TommyT-Bone | Re: Sound deadening seems to be worthwhile | ||
There ya go! Dead'n the noise pollution from outside so ya can hear the noise pollution inside. Rock on |
Posted on: 2008/7/20 20:22
cuisinartvette | Re: Sound deadening seems to be worthwhile | ||
It was definitely noticeable then?
How much do you think the stuff weighed you put on? |
Posted on: 2008/7/20 21:37
You will be redirected to that thread. Click here if your browser does not automatically redirect you. |
pianoguy | Re: Sound deadening seems to be worthwhile | ||
The shipping weight for the 36 sq. ft. pack is about 22 lbs., and the door kit is 6.8.
It was hot and muggy throughout the whole ordeal - projectile sweating was the norm. Coupled with being all cramped up to get into the tight quarters made for a real treat :-P |
Posted on: 2008/7/20 23:19
So I guess you're saying this is one of those great spring or fall projects. |
Posted on: 2008/7/20 23:26
Yeah, though from what I've read, this stuff is easier to work with when it's warm.
I did discover that the nice folks on the assembly line left me a few extra screws and bolts under the carpet. I also discovered moisture in the passenger footwell - not coolant, thank god. I'll have to chase that down and see where it's coming from. |
Posted on: 2008/7/21 1:37
Time for weatherstripping! Matthew |
Posted on: 2008/7/21 4:07
I hope that's it - I have a new weatherstripping kit sitting here, just waiting for ambition and time.
Posted on: 2008/7/21 10:30
Mine used to leak into the footwell, too, so I'm hoping that's all it is for you.
Matthew |
Posted on: 2008/7/21 14:05
JonnyAngle | Re: Sound deadening seems to be worthwhile | ||
FWIW, as long as you just give the panels a good once over with a wet rag to get the dust off, the dynamat will stick. The older stuff you had to clean REALLY good in order to stick, but you can save a little elbow grease with the new stuff. When are you going to put in your indash monitor?
Posted on: 2008/7/21 17:47
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
I probably won't tackle the sound system until either this fall or next spring - too busy driving it ;-)
Posted on: 2008/7/21 18:50
Now that I have a full commute under my belt, on a variety of surfaces, I'd have to say I'm quite pleased with the results. It made the car feel "newer", for lack of a better term. On one particularly nasty stretch of freeway that has a couple of frost-heaved joints, CRASH-RATTLE-SQUEAK was replaced by THUD with no drama. Besides isolating sound, I think a big part of what makes it work is that it seems to soak up a lot of the panel vibrations. When I crack it open again, I may add some to the doors, maybe try to fish in there and put some on the backside of the door skin.
Posted on: 2008/7/21 22:18
