452 user(s) are online (41 user(s) are browsing Forums)
Assembly Line Diagnostic Link
biggrizzly Exhaust Configuration for A4?
I just recieved the extension tubes for my EM headers. Merle told me to connect the tubes to the collectors and then mount the converters behind the trans and tubes.
I have only seen that done on C5s and was wondering if anyone else has seen or done it this way?
Suggestions and comments welcome.
I also ordered a pair of Magnaflow mufflers, but just discovered that they may not be 3" inlets.
Posted on: 2008/9/17 2:49
bogus Re: Exhaust Configuration for A4?
I would think that's just too far away for effective cat operation.
The stock L98 central cat does exist there, but gee, it's got both banks feeding it.
Posted on: 2008/9/17 3:31
anesthes Re: Exhaust Configuration for A4?
Boston, MA
Thats where I ran my cats and it passed on the emissions dyno.
A lot of guys run the bullet cats behind the trans.
Any sort of performance application is going to have some hot EGT's to begin with.
-- Joe
Posted on: 2008/9/17 11:47
jsup Re: Exhaust Configuration for A4?
1778 Posts
Like this?
[IMG]http://pic80.picturetrail.com/VOL857/2991862/10180626/313496748.jpg[/IMG]
Posted on: 2008/9/17 14:01
Lichen Re: Exhaust Configuration for A4?
Scottsdale, Arizona
166 Posts
EM did my installation for me and put the cats behind the tranny. I had to use heated O2 sensors, but passes emissions.
jpg  cats1.jpg (33.08 KB)
838_48d119389b535.jpg 500X375 px
jpg  extensions.jpg (37.21 KB)
838_48d1194928e7c.jpg 500X333 px
Posted on: 2008/9/17 14:50
biggrizzly Re: Exhaust Configuration for A4?
Thanks guys... That's what I was looking for.
I need to print those out and show the monkeys at the exhaust shop.
This the shop down the road from me. I think they'll do a good job.
http://www.southernmdauto.com/main_page.html
Posted on: 2008/9/17 15:02
CentralCoaster Re: Exhaust Configuration for A4?
Why are you running dual 3"? That's ridiculously big.
Posted on: 2008/9/17 19:24
BrianCunningham Re: Exhaust Configuration for A4?
That's the size of my B&B's
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/BayStateCorvetteClub/members/Brian%20Cunningham/blower%20build/bb_exhaust.jpg[/IMG]
My EM's
[IMG]http://i242.photobucket.com/albums/ff87/swiftwood/BayStateCorvetteClub/members/Brian%20Cunningham/blower%20build/emHeader.jpg[/IMG]
Posted on: 2008/9/17 19:44
Everything else is 3", header collectors, cats, and extensions. It will probably make no difference that the mufflers neck down a bit. The stock mufflers do the same thing.
Posted on: 2008/9/17 20:00
3" all the way back is like having an exhaust system that increases in diameter.
Exhaust cools, and slows down. The ideal exhaust system would actually taper down as it goes back. And it'd be as small as possible before measurable restricting power.
I think Vizard had something like 2.2 cfm / hp, which is actually slightly less than dual 2.5s on a 300rwhp car. 3" pipe is 44% larger than 2.5" pipe.
You don't have to maintain the collector pipe size.
Posted on: 2008/9/17 20:05
Well .... It's moot now.
They just arrived in the "Big Brown Truck" and they look sweet!! 3" inlet. All Stainless with pipes that connect to the system. I think they call this an axle back system instead of the full Cat-back
Posted on: 2008/9/17 20:37
