278 user(s) are online (240 user(s) are browsing Forums)
wesmigletz Engine Swap Track Results are in. Post your performance predictions
Land of Fruits and Nuts
325 Posts
Didn't actually road test the new engine until last night. An assortment of mishaps and defective new parts contributed to the time crunch. Anyway, we made it to the track and back. I'll post the A and B combos, but I will save my driving impressions and track results until we see some of the predictions.
Oh, and if you're the guy who called while I was driving home from the track, keep the information private for now.
Old Combo, the original, matching numbers 327/300 HP engine:
1962 327 block, + .040"
3.85" Stroke
18 CC dish piston
6.00" SJ Manley Rods
1962 # 461 heads (some clean-up work)
$55 re-grind cam, specs below
Low-rise dual plane intake
750 vac secondary carb (#3310 Holley)
1 3/4 Super Comp long tubes, 2 1/2" exhaust
700R4, 1800 - 2200 stall converter
3.36 P Case posi
235/60/R15 ET Street radials
Went 12.79 @ 107.6 on 10/19/08 mid 80s temps
New Combo the engine from my 1972 C20
1972 350 block, + .030"
3.75" stroke
12 CC dished piston
5.7" rods
180 CC Dart Pro 1 Platinum Aluminum Heads
Engle HR cam, Sealed Power Retro-fit HR Lifters
.492/.501" 223/232*, 271/282* adv on a 112* LS; I put a 1.6 rocker on the intake and a 1.5 rocker on the exhaust
Rest of the car remained the same. What do you think the results were?
What kind of performance does one get for:
Roller cam, cam button, HR lifters, push rods $800
Aluminum Heads $1250
Aluminum Water Pump $140 (the pulley misalinment was thrown in for free!!!)
Posted on: 2008/11/23 4:51
bogus Re: Engine Swap Track Results are in. Post your performance predictions
Posted on: 2008/11/23 5:35
Matatk Re: Engine Swap Track Results are in. Post your performance predictions
12.35 @ 111
Posted on: 2008/11/23 12:46
jsup Re: Engine Swap Track Results are in. Post your performance predictions
1778 Posts
Did the car hook the same?
That being said, we don't know the condition of each motor.
Heads and roller cam, good for 70 HP maybe 100, max?
The rest wasn't really a performance improvement, like the water pump, even with the alignment issue.
so I wouldn't expect much from a head/cam Then you have the intake...if there's a 125 HP difference I'd be surprised.
What's 125 HP worth?
I'll go with Andy...12.25 at 112
Posted on: 2008/11/23 13:49
wesmigletz Re: Engine Swap Track Results are in. Post your performance predictions
325 Posts
Some interesting eplies. The first engine was fairly fresh. It had about 8000 miles on it, 5000 of which from when we drove it to Bowling Green and back.
The first two passes were my quickest. The car hooked on both. However, later in the day (after I was told I needed to lift), the car spun as I made some tuning changes. The first motor hooked consistently with the DRs.
I'll post the actual results this evening.
Posted on: 2008/11/23 16:28
1778 Posts
So the first motor ran 12.79 with drag radials and the new motor was on street tires?
How was the bottom end of the truck motor?
Based on your last pass are you saying the new motor is not tweaked as far as the tune goes?
Posted on: 2008/11/23 16:37
325 Posts
All track times used in this comparison were with same pair of Mickey Thompson ET Street Radials. The M/Ts were purchased new in October this year.
The truck motor had fresh rings/bearings. The cam/lifters and heads were new. The first miles on it were Friday afternoon (11-21-08), then we drove it to the track on Saturday morning. The track is about 125 miles each way from my house. So, the engine had 150 miles on it give or take for the first race.
The new engine was filled with 15W40 diesel oil, just like the old one.
I doubt the aluminum Edelbrock water pump freed any power vs the stock replacement cast iron one on the other engine, it did trim weight, and being a direct replacement part, contributed handsomely to the pulley misalignment issue.
Posted on: 2008/11/23 16:50
cuisinartvette Re: Engine Swap Track Results are in. Post your performance predictions
Weight reduction of the pump alone has gotta be worth say, um...2 seconds.
Are you going to keep the same gears and converter in there or any plans down the road to upgrade?
Posted on: 2008/11/23 17:06
1778 Posts
OK cool, so you have two fresh engines with good tunes, the basics are covered.
Posted on: 2008/11/23 17:11
Calm Re: Engine Swap Track Results are in. Post your performance predictions
Vancouver, Canada
608 Posts
I only guess at breaking into 11's because he's so mysterous about this.
What's your C1 curb weight?
What tire pressure?
Posted on: 2008/11/23 18:23
325 Posts
I've never weighed the car, but with me in it, it probably weighs 3200 - 3300 lbs. I ran the ET Streets at 20 LBS pressure (same as the previous tests).
Cuisinartvette, I'm hesitant to change to a higher stall, because I am running a frame rail cooler. I'm worried about frying the trans if I get stuck in traffic. WRT gears, not sure. If anything, I'd like to replace the gears with something taller. The tallest they make for my rear is a 3.08
Posted on: 2008/11/23 19:04
1778 Posts
So wes, were you happy with the times?
Posted on: 2008/11/23 19:29
325 Posts
No! Then again, I wasn't completely surprised.
Posted on: 2008/11/23 20:01
wesmigletz Driving impressions
325 Posts
The car idles somewhat smoother, albeit with less manifold vacuum than the solid F/T / dual plane combo.
The drivability was greatly improved, and based on the trip to Bakersfield, the gas mileage appears to have picked up as well. Less throttle is required during driving, and was especially noticable driving through the Tejon Pass.
So, the cambo of the milder HR cam and the Dart heads improved drivability and throttle response.
Posted on: 2008/11/23 20:36
325 Posts
The results of the cam/head swap were an improvement of .15 seconds in the 1/4 mile, and 0 mph compared to the old dual plane/solid flat tappet combo. The car went a best of 12.64, versus a previous best of 12.79 with the old solid flat tappet/dual plane combo.
I played with both the timing and the jetting one change at a time to reach the results as shown.
Not a bad increase for the cash outlay, huh?
Posted on: 2008/11/23 20:40
Wes, have the numbers for the two heads?
You are saying that the smaller head albeit flowed real well drove better had more response and ran a little quicker?
Gee, another person this seemed to work for. lol
Keep up the hard work.
Posted on: 2008/11/23 20:47
1778 Posts
My wife just asked why I sighed....
Ron, you can't possibly compare the two setups. The only similarity between the two is the VIN number (is that redundant?) and the exhaust.
You're starting to sound like someone else I know. First question is "what are the numbers on the two heads" c'mon.
Perhaps it was the new, more more modern cam, the intake, roller lifters, and roller rockers that make it more drivable? Perhaps the entire combination of modern technology? But to go to the heads? Ron, Ron, Ron.....for shame.
This proves nothing about any one part. C'mon Ron, you're not seriously drawing that conclusion from this and being serious are you? You're just breaking my balls, which I appreciate.
All it shows is that using more modern technology you can produce a more drivable car and run faster than with old technology.
That's all we learned, no more, no less.
Posted on: 2008/11/23 21:44
1778 Posts
On another note wes, any insight as to what the HP numbers were on each?
Posted on: 2008/11/23 21:55
325 Posts
jsup, rather than modern cam, I would look at it as a smaller cam. The lobes on the Engle cam weren't their new generation "extreme" type profile (such as the new comp XFI or Voodoo HR profiles), they were more old school. I also think the heads helped.
My previous combo was no slouch. The same things that held the previous combo back were present in yeterday's combo too:
1. The shift points in the trans are too low, typically around 5000 RPM. I was crossing the line between 5000 - 5100 RPM as well. I am using the stock PG shifter on the 700R4. It is so friggin sloppy (and the car is so squirelly in L1), that I am hesitant to manually shift it.
I think higher shift points would have benfited the first combo even more than the combo from yesterday.
2. My combo is restricted as to what intake it can run due to hood clearance issues. An RPM Air Gap, or a Stealth Airstrike would have been worth 1-2 MPH, even with the less than ideal shift points. The C3B intake is probably older than I am. It defintely wasn't an asset, it's like a Performer, but 2 generations older.
I'm not thrilled with the results, but I am happy I did not slow down. I was expecting to see a 2 MPH improvent and run 12.5X Also, later in the day, I was spinning, which didn't occur with the previous combo on the DRs. I think the jetting and spark were optimised looking at the plugs. Unfortunately, the track told me no more full passes after my 3rd run... now I need to find a hard top.
The car drives better and picked up some MPG, based on my intial drive. Once I fill the tank, I can calculate the MPG for the trip.
Since the cam and heads were each variables, I can't say which added what. The car is responsive, and I do not think the smaller cam would have pulled a 12.6 with a weaker head.
The combo worked, and I could recommend it with clear conscience for someone wanting a mild, streetable (now) proven combo. It would be great in a heavy car, such as a Chevelle. BTW, when I called Engle looking for the cam for my truck (this engine was built for my truck, not the Vette), Engle actually recommended one two sizes smaller (212/218 @ .050" lift)
FWIW, for what it's worth, the combo was enough to beat a late model GTO and a new SRT8...
Wes
Posted on: 2008/11/23 22:09
325 Posts
jsup, I never had either engine on a dyno... engine dyno or chassis dyno. I suspect both are in the 380 - 400 HP range, with the Dart combo making more avg torque, and the Camel Humps making ore peak HP.
The 327 may be going on a dyno soon, but I just do not have the time or $$$ to spend on the truck engine.
In the past month and a half, I've done the following, without quitting my job (in chronological order):
1. Coached my sons soccer team
2. Swapped 1 5/8" headers for 1 3/4" Super comps
3. Raced at Famoso on 10/19
4. 2 supplier audits in Mexico
5. Swapped fom a dual plane to the Team G on the old 327
6. Went back to Famoso on 10/25 and 26 with the single plane intake
7. Pulled the 327
8. Did an in-car cam swap on my friend's 1965 L79 Vette
9. Tuned a 69 Camaro SS and a numbers matching 66 L72 Vette
10. Reported to MEPS for a physical (might be going back on active duty)
11. Assembled and re-installed the truck engine (this was its second time in the 62)
12. Went back to Famoso
As I sit here typing this, the wife is asking me how I did the above, yet manage to ignore a leaking shower head for the past two months.
I dunno, that kinda stuff is way above my pay grade.
Posted on: 2008/11/23 22:21
1778 Posts
7. Pulled the 327
Geeze, you're busy.
So I guess with similar HP, similar times isn't a surprise. Once you dial it in maybe you can knock a few off.
Posted on: 2008/11/23 22:29
You dont need to do anything around the house anymore now that you run 12s. Celebrate and have her cook you your favorite dinner while you slump in a lazyboy drinking beer with the dog..Life is good
Posted on: 2008/11/23 23:55
325 Posts
To be honest, aside from the shower head, she doesn't ask for much. Ever since our first date, when I took her to a Cruise night at Bob's Big Boy in Burbank, I never attempted to raise the bar. As such, she doesn't expect much.
Aim low enough, and you'll meet your expectations every time!
Posted on: 2008/11/24 0:04
Found some pics of the outing "over there"
[IMG]http://i298.photobucket.com/albums/mm274/LS1BLKSS_photo/102_2503.jpg[/IMG]
[IMG]http://i298.photobucket.com/albums/mm274/LS1BLKSS_photo/102_2461.jpg[/IMG]
You know Im kiddin Wes, your wife is a sweetheart.
Posted on: 2008/11/24 0:08
88BlackZ51 Re: Engine Swap Track Results are in. Post your performance predictions
481 Posts
ron, did u attend the races? if so what else was there and how did it perform?
Posted on: 2008/11/24 0:13
No, I was home swordfighting with Jsup and being counterproductive all day.
Havent driven my car since early this year.
Posted on: 2008/11/24 0:22
BeachBum Re: Engine Swap Track Results are in. Post your performance predictions
751 Posts
I used to race Famoso all the time.... does it still have a stench in the air in the summer from the rotting fruit trees or whatever they are from across the road ? That was what I hated about that track.... that and it was a million miles away from OC.
You guys should race Irwindale, only 1/8th mile, but on a cool winter night, its a fast track..... and usually sticky too, I ran some of my best 60fts at that track including several 1.4's.
btw, in a picture above, you're next to a SS F-body, do you know him ? I think its my old racing buddy, DJ.
Posted on: 2008/11/24 0:23
C4 Corvette 436 - Pure Black
1778 Posts
Hey, no one forced you!!!! joke, relax
Posted on: 2008/11/24 0:26
1778 Posts
Clearly, not a married ,man...
Posted on: 2008/11/24 0:27
751 Posts
I'm not sure, but I think you went from some old camel backs to Darts and from a solid flat tappet .520/520 232/232 to hyd roller 222/232 ? Do you feel like you have more rpm to work with now ?
What were your 60's ? And I assume your mph was 107 mph, thus your 1/8th must have been around 84 give or take a mph ?
In any regards, I agree, I wouldn't really be happy with those results, particularily your trap speed.... I would have predicted a 3-4 mph pick-up.... but I'm not sure considering I do not know much about those old camel backs you had and how good they are.
Posted on: 2008/11/24 0:33
1778 Posts
His old cam also had a lot less lift, 492/501.
So the light cam, less duration and less lift, and the crappy intake are probably killing it.
sound reasonable?
Posted on: 2008/11/24 0:50
751 Posts
I don't know, I'm trying to read this right from his original post, but it looks like he went from an original 327 to a new combo with a 350 block, but a 3.75" crank, thus he has a 383, plus he added the Dart cylinder heads and hyd roller cam, which with his 1.6 rr on the intake and 1.5 on the exhaust was a .524/.501 223/232 @ .050".... from an old solid flat tappet grind that would have .520/.520 with a 1.6 rr, and 232/232 @ .050"..... not sure if he was running a 1.6rr, doesn't say, which would change the specs to .487/.487 based upon his .325 lobe. (The new lobe is just a .328)
Both set-ups used the un-named low profile dual plane intake. Which probably does hurt power, but just speculating, I know nothing about it.
If this motor is a 383 and the above is correct, I would definitely be disappointed, even with a restrictive intake, you should be up and above 110 mph with that set-up..... I say this only because, I have run over 110 mph with a bone stock tpi plenum/runners/manifold combination before, thus I'm thinking regardless of how restrictive that intake is, he should still be able to get 110 out of it.
In my opinion, your converter is fine for that set-up, although it would run quicker a little looser.... you're still fine.
But, maybe I'm reading the original post in-correctly....
Posted on: 2008/11/24 1:19
1778 Posts
Post 19.
Posted on: 2008/11/24 1:23
751 Posts
I also just noticed, he has an original 327 sbc block, bored .040" over with a 3.85" stroke...... this indicates the original motor was along the lines of a 396..... considering I believe the original 327's used a standard 4.00" bore, with a 3.25" stroke.....
Thus going from a 396 to a 383 ? Am I reading that correct ?
Posted on: 2008/11/24 1:25
1778 Posts
That's how I see it. Changes it a bit huh?
Plus he had the original heads worked, whatever that is worth.
Posted on: 2008/11/24 1:31
751 Posts
Well, if we're reading it correctly, yeah it changes, both the old and new set-up was not running to its potential.
But, on the intake, fairly common problem, I know edelbrock has several different low-rise intakes to chose from..... don't know if any will fit his application, but certainly worth a look into it.
I'll tell you what though, finding power is what this hobby is all about..... start tinkering and you'll find it. My first time out with my old 383 set-up, I ran 12.2 @ 110 mph.... I was pissed. Took it home, put it in the garage, found a few problems and tinkered with it a bit, the very next weekend it easily ran into the 11's.....just slowly widdled it a down after that through experimentation..... was fun getting a new best almost every weekend for the first few months of dialing it in. I recommend it for everybody.
Posted on: 2008/11/24 1:39
751 Posts
From the other post, it looks like he just pulled out an original numbers matching 327..... thus, I'm thinking his 3.85" stroke in the first post in this thread was a typo mistake ?.......
Makes a big difference on expectations....
Posted on: 2008/11/24 1:45
1778 Posts
Somewhere between fun and frustration isn't it..
1778 Posts
If I understand it right, he had the 327 rebuilt 8000 Miles ago, and stroked it at that time...
Posted on: 2008/11/24 1:46
325 Posts
Clarification :
1st engine: the original, #s matching block, heads, and distributor "327", rebuilt with a 3.85" stroke added
solid cam
Camel hump heads, some port work
2nd engine: 72 truck 350, with a 3.75" stroke
Engle HR Cam
180 CC Pro 1 Platinum Dart heads
The displacements are similar. The first engine has a few more cubes. The second has about .1 more compression.
The first combo was tested on 10/19 with the dual plane, and 10/25&26 with a Team G. Temps were in the mid 80s.
With a team G intake, it went 12.77 @ l08.XX (108.21 IIRC). The biggest problem for the first combo was not getting into its power band, because of the trans low shift points. I cannot manually engage low, and the shifter is loose enough, that I do not manually shift at the track. Foot to the floor, it typically shifts between 4800 - 5000 RPM. That is below peak power for the solid F/T. I suspect that is hurting the E/T and MPH. The 3.36 gears do not help
I think the lower shift points are hurting the first combo more than the second, because the second has a milder cam, and thus a lower peak.
The C3B is not helping. I can't recall ever seeing a SBC MPH better than 108 with a Performer intake... there is a local 73 Vette, with a 415 SBC, Edelbrock RPM heads, and a ported Performer. He used to trap at 108.XX.
Both combos pick-up 24 MPH on the second 1/8", and do between 83-84 on the first 1/8th.
I ran the first combo at CA Speedway this past March (2008) with a Weiand Airstrike (like a RPM Airgap), and no hood. It went 13.17 @108.26 MPH. At that point in time, the 700R4 was stock, and shifted at 4500 RPM, and did not shift firm. Temps were in the 90s.
At LACR, the first combo went 13.24 @ 106.XX with the Airstrike. The car had a TH350 trans, and a 11" 2400 stall. That was on the last day LACR was open on 7/29/2007. LACR is at 2700 feet elevation, and temps were in the mid to upper 90s...
Posted on: 2008/11/24 3:35
751 Posts
Sounds like you have a few things you need to iron out .... then maybe you'll have a better feel for how it performs.
btw, is that Jacks C3 you reference with the 415 ? (Is it orange ?) If it is, tell him I said Hi.... I used to race with him at Carlsbad raceway just about every darn weekend. I will say, his 415 was running over 110 mph though..... so maybe a different guy.
My only note, from racing all of the tracks mentioned in this thread, I know them pretty well, Famoso is the fastest track, California is going to be around a tenth slower..... of course LACR was several tenths back. I hope you're taking all of that into consideration when testing..... California is only a bit slower because its a little over 1000 ft vs the somewhere around 700 ft Famoso is, plus I believe California is slightly uphill, at least the new track there is, when they had it on the otherside, it was level.
good luck !
Posted on: 2008/11/24 4:28
Wes what would it take to get the shifter to work right, Id love to see what it would turn if ou could spin it a little higher expecially with the team G.
Posted on: 2008/11/24 4:36
325 Posts
Beachbum, I don't recall the guy's name, but his car had later "disco Vette" body panels on it. He used to run at the WCCC events. I want to say it was a darker color. He used to trailer his car in.
There's definitely performance to be had with either combo. I think the low RPM shift points are hurting the ET and MPH. I need to get my LM-1 on it and see how my fuel curve looks in high gear.
Ron, I probably should drop the trans out when I pull the 383 over Christmas break. I'd like to have some work done to the governor to raise the shift points. That would make a big difference I think. I don't think anything can be done to the shifter.
Once I get the 327 squared-away, I'm tempted to put the stock cast iron intake and rams horns back on, and see if I can still sqeek a 12.XX out of it. Of course the intake and ex manifolds would need to have the bee-Jesus ported out of them...
Posted on: 2008/11/24 5:02
that would be a fun project sounds like.
Posted on: 2008/11/24 5:09
751 Posts
That doesn't sound like Jack, his C3 was boiler plate body panels, but orange. Whoever, it is, I probably know them, I used to race in the WCCC too (I was actually raceday director of operations) the first couple years of the challenge before I was transferred.
Good luck on finding your power..... sounds like you're on the right path.
Posted on: 2008/11/24 20:58
