279 user(s) are online (229 user(s) are browsing Forums)
BeachBum Before and after changes..... per the sim.
751 Posts
I have a dragstrip simulator thats fun to play with.... if anybody is curious about a change if a change in their set-up would result in an improved et, let me know your set-up....I'll see what the sim says. Overall, I think its fairly accurate, but of course, don't spend any money solely on what it spits out.
Here's a sample of an output screen from an old set-up of mine.
[IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-383SR2-1.jpg[/IMG]
Posted on: 2008/11/26 0:39
BeachBum Re: Before and after changes..... per the sim.
751 Posts
Here's an output screen after I in theory loosened up the converter another 800 rpm.
One more time....
[IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/2-383.jpg[/IMG]
Posted on: 2008/11/26 0:41
C4 Corvette 436 - Pure Black
jsup Re: Before and after changes..... per the sim.
1778 Posts
why can't I see the whole page when it blows up?
Posted on: 2008/11/26 0:47
751 Posts
I have no idea.... but you can scale it and see the whole document. With most viewers, down in the lower right hand corner....75% probably works best.
Posted on: 2008/11/26 1:01
751 Posts
Now it all shows up.... go figure.
Posted on: 2008/11/26 1:02
1778 Posts
when I blow it up, I can't see it all and there's no scroll bar.
Posted on: 2008/11/26 1:10
751 Posts
On my screen, they are already blown up in the post itself, no reason to click on them..... are they not on yours ?
Posted on: 2008/11/26 1:21
1778 Posts
nope, the print is so small, I can't read it.
hey, can we ever keep a thread on track
Posted on: 2008/11/26 1:30
751 Posts
I'm thinking nobody cares anyway.... its all good.
btw, here is a direct link to the 1st pic.
Posted on: 2008/11/26 1:48
Qack Re: Before and after changes..... per the sim.
274 Posts
Can you show a plain vanilla '94 'vertte with an automatic comparing the 2.59 vs the 3.07 rear axle ratio?
thanks in advance,
Qack
Posted on: 2008/11/26 1:53
751 Posts
Give me a 20 minutes and I'll do the sim.
btw, can you see the pics okay ?
Posted on: 2008/11/26 2:01
751 Posts
The below is a 94 vette, auto, 2.59 gears, 3350 lb raceweight at a typical midwest track @ 900 ft.
2nd picture, the only change was to 3.07 gears.... looks like it likes it, you improve a couple of tenths. From experience with engines with a flat torque curve like the LT-1, even more impressive gains would be seen by a converter upgrade.
I personally do not know how accurate this is, I don't have a lot of experience with stock LT-1 corvettes.... so take it for what its worth.
[IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-94-259.jpg[/IMG]
2nd pic = 3.07 gears
[IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-94-307.jpg[/IMG]
Posted on: 2008/11/26 2:25
captmike13 Re: Before and after changes..... per the sim.
Hillsboro Mo
2166 Posts
If your using firefox you need to right click and select view image. I have the same problem. Hope this helps.
Posted on: 2008/11/26 3:25
13 GMC 3500 dually
captmike13@yahoo.com
CentralCoaster Re: Before and after changes..... per the sim.
Beach, the software automatically resizes the pics to 300 pixels wide. (Sometimes they randomly show full size though.)
To make they show full size, edit your post so the images are tagged like so: <img width=800> Assuming the pic is 800 pixels wide. On your last post, I went in and edited them to show full size.
Posted on: 2008/11/26 3:32
751 Posts
To make they show full size, edit your post so the images are tagged like so: Assuming the pic is 800 pixels wide. On your last post, I went in and edited them to show full size.
Thanks, I'll try it.
Posted on: 2008/11/26 4:11
274 Posts
Neat! Thanks for the info!!!
Qack
Posted on: 2008/11/26 4:14
