BeachBum | Before and after changes..... per the sim. | ||
I have a dragstrip simulator thats fun to play with.... if anybody is curious about a change if a change in their set-up would result in an improved et, let me know your set-up....I'll see what the sim says. Overall, I think its fairly accurate, but of course, don't spend any money solely on what it spits out.
Here's a sample of an output screen from an old set-up of mine. [IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-383SR2-1.jpg[/IMG] |
Posted on: 2008/11/26 0:39
BeachBum | Re: Before and after changes..... per the sim. | ||
Here's an output screen after I in theory loosened up the converter another 800 rpm.
One more time.... [IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/2-383.jpg[/IMG] |
Posted on: 2008/11/26 0:41
863 cubic inches of C4 & C6 muscle C6 Corvette Z06 - Lemans Metallic Blue C4 Corvette 436 - Pure Black http://www.cardomain.com/ride/3933547 ... chevrolet-corvette/page-1 |
jsup | Re: Before and after changes..... per the sim. | ||
why can't I see the whole page when it blows up?
Posted on: 2008/11/26 0:47
I have no idea.... but you can scale it and see the whole document. With most viewers, down in the lower right hand corner....75% probably works best. |
Posted on: 2008/11/26 1:01
Now it all shows up.... go figure.
Posted on: 2008/11/26 1:02
when I blow it up, I can't see it all and there's no scroll bar.
Posted on: 2008/11/26 1:10
On my screen, they are already blown up in the post itself, no reason to click on them..... are they not on yours ?
Posted on: 2008/11/26 1:21
nope, the print is so small, I can't read it. hey, can we ever keep a thread on track |
Posted on: 2008/11/26 1:30
I'm thinking nobody cares anyway.... its all good.
btw, here is a direct link to the 1st pic. http://i526.photobucket.com/albums/cc342/tldrane/1-383SR2-1.jpg |
Posted on: 2008/11/26 1:48
Qack | Re: Before and after changes..... per the sim. | ||
Can you show a plain vanilla '94 'vertte with an automatic comparing the 2.59 vs the 3.07 rear axle ratio?
thanks in advance, Qack |
Posted on: 2008/11/26 1:53
Give me a 20 minutes and I'll do the sim.
btw, can you see the pics okay ? |
Posted on: 2008/11/26 2:01
The below is a 94 vette, auto, 2.59 gears, 3350 lb raceweight at a typical midwest track @ 900 ft.
2nd picture, the only change was to 3.07 gears.... looks like it likes it, you improve a couple of tenths. From experience with engines with a flat torque curve like the LT-1, even more impressive gains would be seen by a converter upgrade. I personally do not know how accurate this is, I don't have a lot of experience with stock LT-1 corvettes.... so take it for what its worth. [IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-94-259.jpg[/IMG] 2nd pic = 3.07 gears [IMG width=791]http://i526.photobucket.com/albums/cc342/tldrane/1-94-307.jpg[/IMG] |
Posted on: 2008/11/26 2:25
captmike13 | Re: Before and after changes..... per the sim. | ||
If your using firefox you need to right click and select view image. I have the same problem. Hope this helps. Mike |
Posted on: 2008/11/26 3:25
CentralCoaster | Re: Before and after changes..... per the sim. | ||
Beach, the software automatically resizes the pics to 300 pixels wide. (Sometimes they randomly show full size though.)
To make they show full size, edit your post so the images are tagged like so: <img width=800> Assuming the pic is 800 pixels wide. On your last post, I went in and edited them to show full size. |
Posted on: 2008/11/26 3:32
Thanks, I'll try it. |
Posted on: 2008/11/26 4:11
Neat! Thanks for the info!!!
Qack |
Posted on: 2008/11/26 4:14
