85L98-84L83 | Changing O2 sensor on 85 vette. | ||
I was watching a show and they changed the o2 sensors on a truck just because of the milege on it. Would this help on a vette for performance and fuel economy? Should these o2 sensors be changed?
Posted on: 2008/12/18 20:17
85 vette - 3.54 gears,pulleys,160 stat,hypertech chip,K&N,no cat,B&B cat back,cut air lid,TB bypass,air pump elim pulley,air foil,Torque thrust II wheels,maaco paint job 84 vette - K&N,renegade,2 inch TB's,adustable fuel pressure to 15 psi,air pump e... |
jsup | Re: Changing O2 sensor on 85 vette. | ||
They are cheap. But typically unless you get a code, it will make no difference on performance.
Posted on: 2008/12/18 20:22
CentralCoaster | Re: Changing O2 sensor on 85 vette. | ||
An o2 sensor has to stray pretty far before it throws a code, and it will effect performance before that.
Supposedly they can be tested. If you're on your original, I would recommend changing it. What is your mpg on the freeway? |
Posted on: 2008/12/18 20:44
Matatk | Re: Changing O2 sensor on 85 vette. | ||
I've never really looked in to it much, but your post made me wonder so I've been looking stuff up on the internet. Found a replacement schedule on a few automotive sites:
Quote: OXYGEN SENSOR REPLACEMENT Guess it's time to replace mine since I'm sure it's the original one. Can't hurt for what, $25? Matthew PS - I read you have to coat the threads with conductive anti-seize before installing the new one. |
Posted on: 2008/12/18 22:39
Thought I'd update. I picked up a new O2 sensor at autozone yesterday since I was out. Paid $23 with tax and everything. Found them on ebay for about $21 shipped so I don't feel bad about that. Came with the anti-seize on the threads already.
Matthew FYI - Bosch #12014, oem replacement. I didn't feel like splicing the wire, this one came with the plastic adapter already on it. |
Posted on: 2008/12/23 19:08
85L98-84L83 | Re: Changing O2 sensor on 85 vette. | ||
Does the 85 vette have one or two O2 sensors?
Anybody know the part number? |
Posted on: 2008/12/23 23:11
Jeffvette | Re: Changing O2 sensor on 85 vette. | ||
Delco AFS21 requires only 1. |
Posted on: 2008/12/23 23:22
Schrade | Re: Changing O2 sensor on 85 vette. | ||
Yup. If your tune is good, you don't even NEED an O2 nope. BUT, if you've been runnin' with a bad burn, and some heavy carbon fouling is left on the sensor heads, it might need a toothbrush goin' through the grooves to clean it. Even then, you gotta' make sure the burn is right first... |
Posted on: 2008/12/24 5:18
