141 user(s) are online (107 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
wesmigletz Fired up my 1965 Chevelle
Land of Fruits and Nuts
325 Posts
Fired up the 65 for the first time in almost a year. I haven't really driven the car in the past 4-5 years, because I've let other vehicles take priority, and the 62 has been using the Chevelle's carb for the past couple of years. It has a mild 496, a TH350, 11" Holeshot converter, 12 bolt posi, 4WPDB, QR PS, and a fresh suspension rebuild.
I did the work 4-5 years ago, but have put less than 200 miles on the car since. I got the engine running good, and I got the tail lights working, but have no brake lights or turn signals (flashers???). I'm going to drive it around the block a few times when the wife gets home. I plan to start sorting the car out once I get the stroked 327 back in the C1.
I can't wait to start driving it again...
Posted on: 2009/1/3 1:57
bogus Re: Fired up my 1965 Chevelle
wow. Tons of potential there! Super cool!
Posted on: 2009/1/3 2:00
wesmigletz Re: Fired up my 1965 Chevelle
325 Posts
Andy,
It was one of the nicest driving cars I ever owned. I'm not sure what the future holds for it, but I tempted to pull the BB and put a milder engine in, possibly my trucks old 383, or a LSx and make it a daily driver again... I'm thinking that if I can get the wife driving the Chevelle again, maybe I can start having some fun with the 62...
BTW, I'm about to put a belt on the PS pump for the first time. Are you aware of any bleeding procedures that need to be followed?
Posted on: 2009/1/3 2:15
Danspeed1 Re: Fired up my 1965 Chevelle
Mooresville, North Carolina
1121 Posts
The wives get in the way of everything!!
I feel ya.. We haven't drive the C6 much yet because it needs tires and its been snowing like crazy here in NY..
So she takes my Impala SS with 55K miles... and I drive the monte with 200K miles.
DG
Posted on: 2009/1/3 4:04
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
1121 Posts
And IM NOT EVEN MARRIED YET!!!
DG
Posted on: 2009/1/3 4:05
1996 Ford Explorer
2009 Cadillac CTS-v
325 Posts
Dan, generally speaking, the wife approves of just about everything I do for the 62, as long as it doesn't affect the drivability.
However, when I want to do something to the truck or the Chevelle, that's when she starts to raise an eyebrow. She enjoys driving the Vette (and I'm sure the attention it garners has something to do with it), and thus Vette repairs/maintenance/upgrades are a priority.
Unfortuantely, the truck and Chevelle get the short end of the stick. The truck was my DD until gas prices went way-up. Since then, I've been driving the wifes old Tercel, which now has 209K miles...
Posted on: 2009/1/3 4:51
wesmigletz Shake down run
325 Posts
Took the Chevell a few blocks, but didn't get it up to speed. Felt like the trans was slipping a little. May be low on fluid. I'm going to re-install the rear bumber and hood tomorrow, and try to fix the brake lights and turn signals. From there, I plan to use up the old gas, re-fill it, and go back throught the tune.
The engine has a Comp LS6 Nostalgia Plus cam. It drives great, but the cam is a little lumpier than I like. Unfortunately, the engine has a calculated 10.2:1 compression, and I can't really swap to a milder cam.
The 3.0" exhaust, even with the X pipe, is just a bit much, but would probably be livable with a milder engine.
Posted on: 2009/1/3 4:56
pianoguy Re: Fired up my 1965 Chevelle
Too much fun!
Only think I've heard about working the bubbles out on power steering is to turn the wheels lock to lock a few times.
Posted on: 2009/1/3 5:15
1121 Posts
WOW, sounds like you and I are in the same sinking boat. LOL
Your cars are really sweet might I add.
I have a 71 Chevelle by the way in similar shape as yours, only my new 454 is in the basement in pieces, and my 700R4 is in the shed, and my interior is in the garage. Its going to be a very long while before she is on the road again. Chevelles are truly great cars. Mine rode like a dream too. Only problem is here in New York the car gets too much negative attention to get daily driven, which is why I find myself spending so much time on the vette and the impala. I get the death stare every time I talk about putting any sort of $$ into the Monte,... the car "I" wind up driving most days!
DG
[IMG]http://i142.photobucket.com/albums/r97/BG528/Dan%20Impala/730214_9_full.jpg[/IMG]
Posted on: 2009/1/3 5:58
1996 Ford Explorer
2009 Cadillac CTS-v
crash Re: Fired up my 1965 Chevelle
WRIGHT CITY MO 63390
977 Posts
REMINDS ME OF A 65 I HAD BACK IN 68. I PUT A 360 HP BB IN IT AND A 12 BOLT 4:56 POSI IN IT IT. MAN THAT WAS A HOOT TO DRIVE.
AS FAR AS BLEEDING THE P/S FLUID. JUST FILL IT AND START THE CAR. LET IT IDLE FOR A FEW SECS THEN TURN THE WHEEL SLOWLY LOCK TO LOCK. THEN FILL P/S FLUID AND DRIVE IT
Posted on: 2009/1/3 12:51
Matatk Re: Fired up my 1965 Chevelle
Mild 496? Lol.
I think it's pretty sweet. I'd just drive it around like that, a little rat rod vert look. I'd get rid of the 80s camaro rims though.
Posted on: 2009/1/3 14:56
Notorious Re: Fired up my 1965 Chevelle
I've always liked the earliest (64-65) Chevelles and you just don't see that many of them anymore compared to the later ones. Fairly rare car, especially being a rag top. Very nice!
Posted on: 2009/1/3 15:02
cuisinartvette Re: Fired up my 1965 Chevelle
The 496 in there sounds nasty Wes, hate so see ya pull it.
The Rallys are coming off my 67 soon if you need them- Ill be looking for some wider ones with a different offset.
These are 15x7s (front) and 15x8 rear)
Posted on: 2009/1/3 15:39
325 Posts
pianoguy, crash, thanks for the PS tips. I'm going to get a shorter belt today and give it a try.
The 64s and 65s are my favorites, with 65 being my favorite among the two. They are fairly light, ride and handle well. Unfortunately, you can't get much tire under them. One other problem, is that the car being a convertible; you're not able to go fast at the track. Kind of defeats the purpose of having an old car.
matatk, the Torque Thrust D rims on the 62 were pilfered from the Chevelle. When I added rear disc to the 62, the calipers hit the stock rims. So, I swiped the wheels from the Chevelle. The Camaro wheels were relatively cheap and cleared the discs on the Chevelle rear end...
If I ever paint the 62, once I get it all cherried out, I'm going to run the Camaro rims on it, just to annoy the other Vette owners at the cruise nights.
Ron, I'd be interested in the rallys. I'm not sure if a 15X8 will fit the back, though... worth a shot. Any intereest in that LT1 intake?
Posted on: 2009/1/3 16:39
I was just thumbing through my new garage calendar, and found this:
Posted on: 2009/1/4 2:13
I wonder if a 6spd wouldn't fix the daily driveability?
Posted on: 2009/1/4 7:41
Wow. That would be sweet.
Posted on: 2009/1/5 3:01
BrianCunningham Re: Fired up my 1965 Chevelle
This is going to be a sweet build to watch.
Posted on: 2009/1/5 3:34
Which intake Wes?
We can try the Rallyes on for the heck of it. GOing to order mine in the next week or two but the car isnt going anywhere now, more than welcome to try them out.
Posted on: 2009/1/5 6:09
325 Posts
Didn't make any progress on the Chevelle today. Although, I did fire it up for a friend who stopped by while I was pulling the engine out of the 62...
Posted on: 2009/1/5 6:37
325 Posts
cuisinartvette wrote:
Which intake Wes?
Ron, I was referring to the LT1 intake from Pomona. WRT the rallys, I'd like to try them out.
Posted on: 2009/1/5 6:38
No interest from others, it doesnt say Corvette on it even though it would function the same. lol
Wondering if I can do somethign with it.
WRT what is that?
ring ring..
Posted on: 2009/1/5 6:44
325 Posts
WRT - with regards to
Posted on: 2009/1/5 6:53
