188 user(s) are online (83 user(s) are browsing Forums)
BrianCunningham Prepped blocks from Allen Motorsports (Dallas)
Saw this posted 'over there', I showed it to my builder, his guy can't beat it. Just wondering if any of you have heard anything about them.
96GS#007:
I'm having Allen Motorsports supply and prep a block for my 383 project. $995 delivered. 89FX3 used them and was quite pleased with the result. Digging around on other forums has also turned up nothing but praise.
Description from their eBay store...
SMALL BLOCK CHEVROLET LT1 BLOCKS
FULLY PREPPED - READY TO ASSEMBLE
WHEN YOU NEED MORE STRENGTH THAN THE FACTORY GM BLOCKS CAN PROVIDE - WE HAVE THE SOLUTION FOR YOUR HIGH HP APPLICATION
EACH BLOCK HAS BEEN THERMALLY CLEANED AND MAGNAFLUXED TO INSURE QUALITY AND INCLUDES THE FOLLOWING:
STEEL FOUR BOLT SPLAYED MAIN CAPS
ARP MAIN STUDS
YOUR CHOICE OF BORE SIZE - 4.020 - 4.030 - 4.040 - 4.060
DECKED 90 DEGREES PARALLEL TO THE CRANKSHAFT CENTERLINE
CYLINDERS FINISH HONED FOR MOLY RINGS
CLEARANCED FOR UP TO 3.875 STROKE CRANKSHAFTS
SCREW IN OIL GALLEY PLUGS
ONE PIECE REAR MAIN SEAL
ACCEPTS FACTORY OR AFTERMARKET ROLLER CAMS
BRASS FREEZE PLUGS
NEW CAM BEARINGS INSTALLED
ALL MACHINING PERFORMED WITH BHJ FIXTURES
FINISHED WITH VHT SATIN BLACK ENGINE ENAMEL
THANKS FOR LOOKING AND BE SURE TO CHECK OUT OUR EBAY STORE FOR MORE QUALITY PERFORMANCE COMPONENTS
ALLEN MOTORSPORTS
626 SOUTHEAST DR.
DALLAS, TX 75217
214-391-7562
http://cgi.ebay.com/ebaymotors/LT1-SB ... emZ260323063057QQtcZphoto"]e-bay link
Posted on: 2009/1/14 19:55
Matatk Re: Prepped blocks from Allen Motorsports (Dallas)
22812 Posts
Looks like a pretty darn good price to me. I'd like to hear some feedback. Wonder if they do L98s, too.
Posted on: 2009/1/14 23:41
Matt26R Re: Prepped blocks from Allen Motorsports (Dallas)
Powell, Ohio
76 Posts
It looks like it. Man, that's cheap!
http://cgi.ebay.com/ebaymotors/SBC-Ro ... tcZphoto#ebayphotohosting
Posted on: 2009/1/14 23:55
Special Thanks to our 2010 Sponsors: EBC Brakes, www.TPIS.com, www.redlineoil.com, and Simpson Race Products.
22812 Posts
Matt26R wrote:
Wow. Even with shipping I don't think I can get it that cheap locally. Figure the cost of a good block, machining, etc. Impressive.
BTW, what's a BHJ fixture?
Posted on: 2009/1/15 0:11
CentralCoaster Re: Prepped blocks from Allen Motorsports (Dallas)
Short block stroker for $3500.
What's the difference on blocks from a 1-pc main L98 to an LT1?
Posted on: 2009/1/15 0:34
Danspeed1 Re: Prepped blocks from Allen Motorsports (Dallas)
Mooresville, North Carolina
1121 Posts
Its funny this thread came up, I was looking at something similar on Ebay. It almost doesn't pay to send a used block out to a local machine shop. I wonder what the quality of the block and specifically the bores are? I've read that some of these places just punch these things out, without plates, and that makes for some low quality junk? I don't know anything about the machine work process, but it would be interesting to find out more about this company's reputation.
DG
Posted on: 2009/1/15 2:24
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
bogus Re: Prepped blocks from Allen Motorsports (Dallas)
20861 Posts
The cooling ports are totally different... so are the bolt patterns for the heads.
Posted on: 2009/1/15 2:41
20861 Posts
I have added my thoughts:
STEEL FOUR BOLT SPLAYED MAIN CAPS - Sweet
ARP MAIN STUDS - Good choice
YOUR CHOICE OF BORE SIZE - 4.020 - 4.030 - 4.040 - 4.060 - Nice to have options
DECKED 90 DEGREES PARALLEL TO THE CRANKSHAFT CENTERLINE - Makes sense
CYLINDERS FINISH HONED FOR MOLY RINGS - Cool, but I didn't realize that Moly rings required a different hone.
CLEARANCED FOR UP TO 3.875 STROKE CRANKSHAFTS - Good.
SCREW IN OIL GALLEY PLUGS - Nice.
ONE PIECE REAR MAIN SEAL - Duh.
ACCEPTS FACTORY OR AFTERMARKET ROLLER CAMS - I would hope.
BRASS FREEZE PLUGS - Ok.
NEW CAM BEARINGS INSTALLED - Nice.
ALL MACHINING PERFORMED WITH BHJ FIXTURES - Ok.
FINISHED WITH VHT SATIN BLACK ENGINE ENAMEL - Rattle Can?
Finally, what about cleaning up the oil journals and cooling ports? Any epoxy on the valley?
Otherwise, it looks like a fair deal.
Posted on: 2009/1/15 2:46
