64 user(s) are online (39 user(s) are browsing Forums)
C3 Technical  >
Trae1976
Johnson City, TN
832 Posts
I’m no electrical expert, so maybe one of you can help.
Last year I replaced my taillight and backup light bulbs with LED replacements, like those that SuperBrightLEDs offers. They work flawlessly and look great behind new lenses. :thumbleft:
So then I wanted to replace my front turn signal bulbs, and that’s when the issue started. At first, they would not work – all would light up as if there was one missing, and no signal function. I assumed this was an issue with low resistance, so I replaced the standard flasher with a Tridon Electro-Mechanical unit. After that, they functioned properly, until…
I turned on the headlights, and they all lit up again with no signal function. So I then tried a different flasher I had read good things about – a Signal-Stat #262 Heavy Duty Electronic. But I’m still lit up with no function ... only with the headlights on.
Any ideas why?
I know about the load resistors I can install, but I want to make sure that’s what I need before I go splicing wires.
Your input is much appreciated.
Posted on: 2009/2/17 15:43
red_johnny
Its sounds like the resistors. I had a similar problem with my bike. Put LEDs on and they flashed alot faster but for me that actually worked in my favor as the new flash pattern brought more attention. But in your case using older electronics sounds like the resistor problem alot of people encounter when replaceing both the front and rear signals.
Posted on: 2009/2/17 16:47
TimAT
Gladstone, MO (Kansas City)
38 Posts
I'd bet on a poor ground. Without the headlights, the resistance seen by the turn signals is enough to get the flasher to work. With headlights on, they also use some of the capacity of that ground connection.
I know it sounds odd, but it is a possible cause- especially after two different flashers. Think of all the weird oddball stuff that happens when a ground gets bad on a Vette.
Posted on: 2009/2/17 17:15
red_johnny
I dunno, its possible but if the lights worked before with headlights then it should be no differant now seeing as the LEDs are very low draw. If a ground it would have to be at the flasher unit that was replaced, check that ground first, it should be ground to the nearest part of the frame.
Posted on: 2009/2/17 17:32
Aktbird
Mchenry, Illinois
11 Posts
Your marker lights are back feeding into the park and signal lights. The way they are wired from the factory works good with incandescent bulbs, but not with the led's.
Posted on: 2009/2/17 22:07
'75 L-48 Millenium Yellow
Durango_Boy
I agree, I had a very similar problem, except it was opposite. I am actually running my marker lights piggy backed from the front signal wiring and ditching the marker light circuit hoping to bypass that problem.
My signals would work fine unless I turned the headlights on, and all signal bulbs INCLUDING the interior green arrow indicators would turn on.
Posted on: 2009/2/17 22:28
Aktbird
Mchenry, Illinois
11 Posts
You can test this by removing just the bulbs from both front marker lights and try the signals and lights again, it should all work fine. With the led's you will probably have to either sacifice the function of your front corner markers or the signal operation of the front corner markers.
Posted on: 2009/2/18 0:09
Durango_Boy
Yeah see I had issues and the LEDs in the markers were constantly lit when the headlights were on. I pulled them and put the stock bulbs back in and that problem went away. The marker lights were such an oddly designed system that LEDs in them cause a lot of problems and mine weer compounded because I replaced the interior indicators as well. I think the interior indicators act as the ground for the markers until the signals are turned on and then the bulbs in the markers are the ground...or something goofy like that. Either way, I'm leaving stock bulbs in the interior indicators and ditching the marker circuit in favor of 1157 side lights that will piggy back and mimic the front and rear lights.
Posted on: 2009/2/18 14:09
red_johnny
I wonder if there is a good fix that solves the problem and allows you the use of the front lights? I wonder if it is a ground problem then if its possible to just run a ground at every light? Does sound like a weird problem though. I am sure when the system was designed they were not thinking about LEDs...lol.
Posted on: 2009/2/18 14:42
Durango_Boy
The problem is that the way it was designed, it was set up so the side lights would blink in unison with the signals but opposite sync with the hazards. I think whatever makes them operate like that is the main reason they are hard to wire using LEDs on either the markers or interior indicators.
I was told the rear lights don't matter and that the flasher only sees the resistance from the front anyway. The front signals seem to be okay as LEDs too with the proper flasher but when LEDs are installed in the markers or dash arrows everything gets mucked up.
Posted on: 2009/2/18 14:47
red_johnny
Oh, now I see. That would be a hard problem to overcome. It would require some custom work and new wiring.
Posted on: 2009/2/18 15:19
Trae1976
Johnson City, TN
832 Posts
Okay, I finally had the chance to fool around with this a little bit more…
This is exactly what mine was doing.
Spot on! I tried that and it worked just as you described.
As of right now, I have LED bulbs in all markers, taillights, backup lights, and front signals. Here’s how it works:
With park lights and headlights off, everything functions as normal.
With park lights or headlights on, everything functions except the front markers – those remain unlit as long as the lights are on. Also, the signal flashing is a slower pace than with lights off. And this only worked with the HD electronic flasher – neither the electro-mechanical nor a thermal would produce this much function.
I think I will try this setup for awhile, at least until someone (DB? ) comes up with a better solution. I don’t mind sacrificing the front markers at night, since my front signals are much brighter now. The slower flashing may bother me some – guess I’ll find out.
Posted on: 2009/3/18 14:19
Durango_Boy
Reach up through the front driver's grill opening and feel your way up the marker harness to the main harness where the ground wire breaks away and bolts to the bottom of the core support. I found that mine had a VERY worn and partly broken wire there. I'm going in a completely different direction so when I repair this ground I may not see if it was the problem or not.
I do know that MOST signal and marker issues are ground issues. That one ground wire is not only very hard to get to to check but it also the ground for the front markers, which seems to be the common point in all of our troubles. I know from the condition of mine that it was not a solid ground and you may have the same issue. The sheath was dried and cracked and the wiring was old and breaking.
Posted on: 2009/3/18 14:27
Raphiki
10 Posts
DB I sure wish you'd finish this project so we can all see how these experiments work out!
Posted on: 2009/3/21 17:28
Durango_Boy
Working on it. I got the markers all modified and the fronts are wired to the front signal system. I still have to finish the rear...tomorrow?...and install the dash panels and test everything.
I'll start a thread with pics and explanations, assuming it all works as planned.
Posted on: 2009/3/21 22:30
