136 user(s) are online (79 user(s) are browsing Forums)
Epimax Lowering Project Completed
Wilmington, NC
1814 Posts
It's done! Here are a few before/after Pics!
jpg  vette1.JPG (23.89 KB)
1871_499bf796272c7.jpg 499X218 px
jpg  z3.JPG (86.60 KB)
1871_499bf7bfec7fd.jpg 640X192 px
jpg  aa2.JPG (52.93 KB)
1871_499bf7eed241d.jpg 346X162 px
jpg  z5.JPG (81.43 KB)
1871_499bf80bdd616.jpg 490X203 px
jpg  z9.JPG (108.63 KB)
1871_499bf8198ef22.jpg 640X208 px
jpg  z10.JPG (145.45 KB)
1871_499bf828b01a9.jpg 640X480 px
jpg  z6.JPG (124.41 KB)
1871_499bf83d8141a.jpg 479X330 px
Posted on: 2009/2/18 12:00
Matatk Re: Lowering Project Completed
22810 Posts
Has the ride changed at all? Ie, bumps hit harder, etc? I can't lower mine up here....Chicago roads would kill it.
Posted on: 2009/2/18 12:26
Epimax Re: Lowering Project Completed
Wilmington, NC
1814 Posts
Too soon to tell! I completed the job yesterday afternoon, and only took it around the block to let the suspension settle. I'm going to take it to get an alignment, so we'll see! I've definitely got to be careful not to run over anything, because it's quite a bit lower than it was!
Posted on: 2009/2/18 13:05
pianoguy Re: Lowering Project Completed
Nicely done - looks great!
Posted on: 2009/2/18 13:11
Wilmington, NC
1814 Posts
Thank you Sir!
Posted on: 2009/2/18 13:47
biggrizzly Re: Lowering Project Completed
It looks good. How did you bond the new pad? Any different procedure than what has already been published?
Now I got to have you come help do mine!
Posted on: 2009/2/18 13:53
Wilmington, NC
1814 Posts
Thanks!
Well, I modified the procedure a little! I actually sanded down the stock wedges to the desired height with a belt sander and 40grit paper, left off the metal shims, and trimmed the spring retaining brackets accordingly!
jpg  a5.JPG (176.19 KB)
1871_499c14da14a6c.jpg 640X480 px
Posted on: 2009/2/18 14:03
Did you do any measuring before or after to see the drop on the front? I have been wanting to do this to mine for a few years and haven't had the "fortitude" to do it. I have no problem diggining into the motor, but suspension stuff gets me a little nervous.
Posted on: 2009/2/18 14:09
Wilmington, NC
1814 Posts
Ha! See, I'm scared to dig into the motor!
I did measure, but only the 'after' measurement. Like a dummy,I didn't think about it until after I had it up on the jackstands, and I was too lazy to take it down just to measure it...
Right now, it's sitting at 26" from top of fender well to ground in the rear, and 25.5" for the front. ( I think that's right..My notes are at home, so I'll check to be sure..it may be 25 and 24.5, respectively...but I can't recall..
I wound up removing 5/8" from the aluminum bracket, which includes the amount of wedge sanded and width of shim I left out... Pic below!
It's not that bad (especially if I can do it!) It was a heck of a lot easier than replacing that damn heater core!
jpg  js2.JPG (79.86 KB)
1871_499c1aa3c451b.jpg 640X480 px
jpg  a3.JPG (163.82 KB)
1871_499c1ab44d64f.jpg 640X480 px
jpg  a4.JPG (140.41 KB)
1871_499c1ac4d0787.jpg 640X480 px
Posted on: 2009/2/18 14:30
CentralCoaster Re: Lowering Project Completed
Those pivots blocks look a little too short to me. I would recommend putting the aluminum shims back in to help avoid spring contact with the frame.
Posted on: 2009/2/18 15:29
CSS996 Re: Lowering Project Completed
Mega Guru
Central PA
3644 Posts
I want to do this mod. Actually I would rather buy somebody beer and dinner so I could watch them do it.
I scrape the chin spoiler about every time I go anywhere though, so perhaps it is not for me.
Is that as high as you had to jack the front end? I swear I've seen other pix where the nose of the car was six feet in the air. Looked scary as a really scary thing.
Posted on: 2009/4/1 1:34
Currently "Between Vettes".
Aardwolf Re: Lowering Project Completed
Fremont, WI
209 Posts
When I did the lowering I really didn't have the car any higher then when I would change the oil. Mine stock height was just under 28" at the front fender. It wasn't really a tough project. I got to replace those torn grease boots so less grease flung on the wheels! I also belt sanded the stock wedge down.
You can get a finger up on top of the spring to see if it's hitting the inboard frame bump.
Posted on: 2009/4/1 1:46
