290 user(s) are online (242 user(s) are browsing Forums)
Also known as NHMS....
400hp427vette Aluminum intake manifold cleaning
Long Island, NY
373 Posts
I am looking for a product that I can use to safely clean my intake without damaging it or anything else on the car. It is original with 40 years of grime on it. It has been washed with engine degreaer but nothing more.
[IMG]http://i260.photobucket.com/albums/ii31/400hp427vette/1969%20corvette/DSC00372.jpg[/IMG]
Posted on: 2009/3/17 1:53
BrianCunningham Re: Aluminum intake manifold cleaning
I'm not sure how to best clean it, but that's one nice looking 'survivor' you got there.
Posted on: 2009/3/17 1:56
CentralCoaster Re: Aluminum intake manifold cleaning
I use brake cleaner, even on the car. That and a toothbrush work great at getting cast surfaces clean and without residue smeared everywhere. The brake cleaner all evaporates, while degreasers turn your dirt into mud and have to be cleaned off with something else. Painted surfaces are the only thing that might get marred instantly from brake cleaner.
Off the car, beadblasting will get it looking like new.
Posted on: 2009/3/17 4:49
cuisinartvette Re: Aluminum intake manifold cleaning
Another vote for plenty of brakecleaner, toothbrush and patience. Tumbling does a good job of bringing out a good finish, soda blasting looks very nice too, is cheap and not abrasive at all, will not change the finish but will look newer than anything else. Local machine shop should be able to do this.
Posted on: 2009/3/17 12:10
Midnight85 Re: Aluminum intake manifold cleaning
Streator, IL.
264 Posts
If it were mine, I remove it and glass bead blast it, as Central Coaster said, it will look like new. While the carbs are off you could use carb cleaner and a toothbrush on them to bring them back too.
Posted on: 2009/3/17 13:00
I was going to suggest that but, the car's worth more if the manifold's never been off.
Posted on: 2009/3/17 16:29
400hp427vette Re: Aluminum intake manifold cleaning
Long Island, NY
373 Posts
Manifold has been off but never cleaned good. The person who restored the car wanted something original and untouched. He told me he chose the manifold since it would have no effect on the opperation of the engine clean or not.
Posted on: 2009/3/20 2:42
