244 user(s) are online (198 user(s) are browsing Forums)
VictoriaVette Wheel Play
12 Posts
Well here is my question I just finished installing new strut rods on my 77 and a friend o mine want me to help him install some adjustable strut rods. So I did and after we were done I noticed that there is some play in the rear tires. If I grab the tire at 3 o clock and 9 o clock everything it nice a tight now play at all. But when I grab the tire at 12 o clock and 6 o clock I can move the tire back and forth about 1/16" of an inch on both wheels. So is this normal? I did not check mine after I was done but I will.
Posted on: 2009/3/24 23:02
1977 Corvette Dark Blue 2nd Owner
L-48, L98 58cc Aluminum Heads,SS Valves, 1.5 Roller Rockers, Comp Cam 270H, Edelbrock Performer RPM Intake, Holley 650 Double Pumper Dual Feed, 96 Corvette LT1 2 1/2' Exhaust Manifolds with 2 1/2" True Duals
Flex A...
Durango_Boy Re: Wheel Play
Grabbing at 12 and 6 and getting movement is a symptom of wheel bearings being bad...not strut rods...as you found that's side to side and all was tight that way.
Posted on: 2009/3/24 23:41
Trae1976 Re: Wheel Play
Johnson City, TN
832 Posts
I was thinking it was the opposite. Could be wrong though.
Posted on: 2009/3/25 0:36
BillH Re: Wheel Play
DB's correct, 6 & 12 eliminates feeling play in any tierods, toerods, etc.
Posted on: 2009/3/25 15:24
Artsvettes Re: Wheel Play
12 Posts
As usual the BS flows out of DB"s mouth. It is an incorrect way to check End Play in the bearings.
1 You need to jack up the vehicle
2 Remove the wheel and out board half shaft
3 Mount a dial indicator to torgue control arm and rest the pointer on the flange or spindle
4 Grasp the rotor and move it in and out axially in and out and observe the readings...........001-.008 limit
The 6 and 12 rock will indicate excessively worn torgue arm bushing or stut arm bushings
Posted on: 2009/3/26 16:55
CSS996 Re: Wheel Play
Mega Guru
Central PA
3644 Posts
There are more respectful ways to disagree. Especially if you want to be a member here.
Posted on: 2009/3/26 22:25
Currently "Between Vettes".
Just so we're clear I didn't tell him it was a way to measure anything...I said it was a symptom of wheel bearing problems.
Posted on: 2009/3/26 23:25
