216 user(s) are online (186 user(s) are browsing Forums)
itlgo2 engine video
Missouri
288 Posts
1990 ZR-1 LT-5
Posted on: 2009/4/1 8:03
Durango_Boy Re: engine video
That's awesome. Hope to see you and that car at a few car shows this summer. Please tell me you plan to attend the Hooters Bikini car wash show May 9th here in Columbia.
I saw a video once of an LT5 where the guy stood a nickle up on it's edge on the plenum and start the engine. The nickle did not fall. He then slowly revved it up to about 4K RPM, and instead of falling over the nickle started spinning in place like a wheel. Totally awesome and I wish I still had the video. Truly a testimate to a well balanced engine.
Posted on: 2009/4/1 13:30
BrianCunningham Re: engine video
Sweet!
Posted on: 2009/4/1 14:33
itlgo2 Re: engine video
Missouri
288 Posts
thanks, just got it done, i'm pretty happy with
the results
Posted on: 2009/4/1 18:25
captmike13 Re: engine video
Hillsboro Mo
2166 Posts
That sounds great. I sure wish I had done some research before we bought this one. I want one real bad. The wife says no because a little thing called no job.
Posted on: 2009/4/1 19:09
13 GMC 3500 dually
captmike13@yahoo.com
Sweet90 Re: engine video
Edmonton, Alberta
1143 Posts
the results
You should be. Beautiful engine. LT5's are
Jim
Posted on: 2009/4/1 19:19
Missouri
288 Posts
I am planning on makin the trek to columbia for the
hooters car wash day. so what are the particulars is it a car show?? Enlighten me
Posted on: 2009/4/4 3:46
Dads90 Re: engine video
Pearland, Tx
318 Posts
Truly unbelievable engine. Nice Vid, even without a girl.
Posted on: 2009/4/4 3:54
