Curtis1974 | Radio Antenna Not Working? | ||
Okay, I forgot to mention this the other day about my 95. The only thing that I found on the car so far that doesn't work is the radio antenna. I can here the motor running when I first turn the car on and when I turn it off so I know that is working. It's stuck in the up position. Any ideas?
Don't these have a plastic track that run in and out of the motor that extends the antenna? I think that might be it. Is there a rebuild kit out there or is buying a whole new assembly the way to go? |
Posted on: 2009/4/14 4:05
Dads90 | Re: Radio Antenna Not Working? | ||
There is a mask replacement kit. Found mine on Ebay. Usually the nylon gears on the old mask break off from deteriation. Its a fairly easy fix, but it is tricky to get the new one to feed back in.
Posted on: 2009/4/14 4:28
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. ![]() |
Pcolt94 | Re: Radio Antenna Not Working? | ||
There are kits on Ebay that come with a special tool for the top nut for the mast. Its nice having the tool since the nut can be tight and prevent a scratch from a slip with a long noise.
If the mast comes out and the nylon gear is not as long as the new one, then there is a piece broken off down in the antenna assembly itself. For this problem the antenna assembly has to be removed from the car. Getting it out of the car is a bit of work. And then the getting it apart could be another challenge. My antenna side plate did not have screws (as some do) but had plastic rivets. Had to cut off the rivet head carefully preserving the shaft. Then I drilled the shaft with a small hole and used a small self tapping screw to re-assemble the cover back on. Once the cover was off it was a relativity easy job of removing the debris, cleaning it up and lubricating it again. Once assembled you have the choice of installing the mast before or after installation of the antenna back into the car. I think I did it back on the car so I knew proper orientation if the mast teeth. I believe the teeth face the inside (or right side) of the car. ![]() |
Posted on: 2009/4/14 10:50
Curtis1974 | Re: Radio Antenna Not Working? | ||
Thanks guys. Sounds like it's going to be a challenge nonetheless!
Posted on: 2009/4/14 11:03
Car's approximate birthday: June 29, 1974 Purchase date: 11/23/2003 Custom candy green - Vortec roller motor - TT2's - Custom sound system - Hooker side pipes - Babe magnet :thumbleft: |
1Fast04Vert | Re: Radio Antenna Not Working? | ||
Actually the teeth face outside (or left side), If you don't have to pull the motor it is a very simple 10 minute job. |
Posted on: 2009/4/14 12:45
CSS996 | Re: Radio Antenna Not Working? | ||
Mega Guru
You can get a mast kit from our very own Jeffvette. That is where I got mine.
On another note, I found that PKE fob this morning. I will try to get it mailed out today. |
Posted on: 2009/4/14 13:16
Currently "Between Vettes". ![]() |
tjpreul | Re: Radio Antenna Not Working? | ||
I did notice that in the picture. That was the first repair I did on mine. I have a plastic track, somewhere in the garage. The previous owner gave me the track, and a new replacement unit. I installed the new replacement unit. Also I do have the old motor that works, if you want to try to get it repaired before removing yours.
Posted on: 2009/4/14 13:19
I stand corrected , your right. Could not remember from 2 years back is why I said I believe and was not sure. I checked the book and it is to the left. Get that little special socket tool for the nut and life will be better. |
Posted on: 2009/4/15 0:12
Tyler, We'll hook up sometime and we can work on this together. Thanks man! |
Posted on: 2009/4/15 3:08
Chris, You da man! |
Posted on: 2009/4/15 3:09
