94 user(s) are online (46 user(s) are browsing Forums)
JDSWHITE93 Nitrous bottle mount questions
Ohio
334 Posts
I saw a Nitrous bottle that let lose inside a guy car. So that got me to thinking about my car so I ordered a blowdown tube for mine. The questions I have is are the bottle mounts enough to hold it in place if it ruptures ? Is there a really good way to secure the bottle in the cargo area so IF it lets lose it stays put ? I have a 10lb Zex bottle with their mounts in mine. Suggestions ?
Posted on: 2009/5/20 17:23
Durango_Boy Re: Nitrous bottle mount questions
You might think about contacting the company that makes it, call their tech line, and ask them the same thing. Chances are they tested their brackets in cars in various situations and maybe they know for sure that their brackets will hold everything secure even in the event of a rupture.
Posted on: 2009/5/20 17:43
CentralCoaster Re: Nitrous bottle mount questions
I thought you weren't even allowed to have the bottle inside the drivers compartment in most rulebooks.
That leaves you with building a compartment or putting it inside the spare tire cover.
Posted on: 2009/5/20 18:55
JDSWHITE93 Re: Nitrous bottle mount questions
Ohio
334 Posts
You gotta have a blowdown tube on it. On a typical TNT night at my track nobody cares.
Posted on: 2009/5/20 19:39
dan0617 Re: Nitrous bottle mount questions
I have a 15lb bottle, mounted right behind the driver's seat, laying down, parallel with the car. I do have a blow-down tube on it. I have a 'vert so mounting will be totally different for you. It just barely fits that way, so even if the clamps let loose for some reason I don't think the bottle could move much. The bottom of the bottle is against the back of the cargo area and the top of the valve is about 1" from the front edge of the cargo area. I have 2 clamps holding it down and they are securely mounted. Also nice that way because I can reach around and open the bottle while driving, and I can turn around in the seat (when stopped) and see the bottle pressure gauge.
Posted on: 2009/5/21 16:57
Ohio
334 Posts
Any other ideas ? Pete K ??
Posted on: 2009/5/26 23:52
PeteK Re: Nitrous bottle mount questions
I mounted mine to a piece of 1/2 inch plywood that was cut to the exact shape of the cargo area, then covered it with red, matching carpet.
Posted on: 2009/5/27 0:00
