Ultraman | Tune up on my 90 question | ||
I am going to tune up my 90 with 53K. Plugs, wires, cap and coil, rotor. Don't know the history on the car so for a winter project I thought I would start fresh for next season. Should I also replace the ignition module at this time? Should that be part of the normal tune up or not? I appreciate the help, Merry Christmas!
Posted on: 2009/12/21 2:44
bogus | Re: Tune up on my 90 question | ||
It's not a normal part for a tune up.
If it's working ok, I would leave it. They don't age out, but they do wear out... and your's can't have enough wear. |
Posted on: 2009/12/21 4:33
Matatk | Re: Tune up on my 90 question | ||
Test your injectors while you're in there. Have you had any trouble with them? Hard starts, etc?
Matthew |
Posted on: 2009/12/21 12:29
Ultraman | Re: Tune up on my 90 question | ||
Injectors seem ok but I can run a test If I can find the thread on how to do it.
Posted on: 2009/12/21 23:58
Dads90 | Re: Tune up on my 90 question | ||
If the injectors are original Multecs, don't run Seafoam thru them. It will kill them. Did mine.
Posted on: 2009/12/30 5:38
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
jhammons01 | Re: Tune up on my 90 question | ||
Posted on: 2009/12/30 5:46
BrianCunningham | Re: Tune up on my 90 question | ||
When's the last time the fuel filter was changed.
cheap insurance. |
Posted on: 2009/12/30 14:20
I put it on new about a month or so ago. It needed it!
Posted on: 2009/12/30 23:39
