251 user(s) are online (223 user(s) are browsing Forums)
Assembly Line Diagnostic Link
djxib Tapping noise above 2000 RPM part two
North Georgia
456 Posts
(from previous thread). 1992 383 LT1 / LT4 heads + Vortech
I got fed up not being able to work out where the tapping noise is coming from. So I removed the supercharger belt and now I can clearly hear the tapping at idle. The tapping gets much worse and very loud above 2000 RPM. I pulled both valve covers and it seems to be more pronounced at #8 exhaust. I re-set the lash and made no difference - still taps like a mofo. To be honest the tapping seems centered at the rear of the intake.
So I threw half a can of seafoam in the crankcase and ran the car for 10 minutes and I am leaving overnight. If it is gone then I had an sticky lifter (which I actually dont hold out much hope for). If it is still tapping, I will remove the intake and throw a new set of lifters in there plus inspect everything.
If it is a lifter it is weird because I put the current set of LS7 lifters (according to SDP they are compatible) about 10,000 miles ago.
Guru comments welcome...
Posted on: 2010/7/13 1:41
Andy
Matatk Re: Tapping noise above 2000 RPM part two
I would suspect a lifter, myself, or a noisy rocker. Are your rocker arms in good condition? What about the pushrod - not bent or damaged?
LS7 lifters should be fine AFAIK.
Posted on: 2010/7/13 1:52
BillH Re: Tapping noise above 2000 RPM part two
Have you tried stickin' a screwdriver in your ear and putting on top of both #8 rocker arm studs?
Posted on: 2010/7/13 1:55
bogus Re: Tapping noise above 2000 RPM part two
what Bill said.
Posted on: 2010/7/13 2:00
Livin_the_dream Re: Tapping noise above 2000 RPM part two
robesonia , pa
516 Posts
what Bill said.
x2 located many of noises that way!
Posted on: 2010/7/13 2:05
pianoguy Re: Tapping noise above 2000 RPM part two
Let's hope it isn't a spun bearing.
Posted on: 2010/7/13 2:45
dan0617 Re: Tapping noise above 2000 RPM part two
Bent or burnt exhaust valve?
Posted on: 2010/7/13 10:57
djxib Re: Tapping noise above 2000 RPM part two
North Georgia
456 Posts
Yep - used a mechanics stethoscope to home in on #8 exhaust. But to the "naked ear" the noise is coming from the intake. Will post results later....
Posted on: 2010/7/13 11:37
Andy
