274 user(s) are online (196 user(s) are browsing Forums)
[IMG]http:/...
Eagle223usa Need an LT4 Guru!
Guru with Eyes of Steel
God's country, Pa
197 Posts
Any LT4 owner know if the original LT4 springs had dampers inside them? I just bought a set from Pace and sent them to my machinist. They came without the internal damper. When I asked if he would use the original dampers he stated that if it needed a damper GMPP would have sent them with the springs. Anyone know? What is the dampers purpose in life anyways? Do I need it? Thanks.
Posted on: 2011/7/24 22:47
God Bless America!
bogus Re: Need an LT4 Guru!
I am checking the Helm right now and don't see anything special.
Posted on: 2011/7/24 22:58
rklessdriver Re: Need an LT4 Guru!
GM factory LT4 springs do NOT have a flat wire damper.
The damper is to reduce spring harmonics. When GM started the LT1/4's one of the big technical advances was in the valve springs. They used a special type of wire that had an ovate crosssection (as oposed to round). The ovate wire springs did not need a damper to keep the spring harmonics under control.
Posted on: 2011/7/25 0:36
Eagle223usa Re: Need an LT4 Guru!
God's country, Pa
197 Posts
Groovy! Thanks Bogus and Reckless, I just never seen one on a SBC without it. I should learn to trust my engine builder. Thanks Guys.
Posted on: 2011/7/25 0:45
God Bless America!
RickAnthony Re: Need an LT4 Guru!
ASE Master Certified
Downers Grove, IL
703 Posts
Cool to know about the spring design... I was thinking back when I installed my take off LT4 heads didn't recall seeing one either, but that was years ago..
Posted on: 2011/7/25 1:03
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
BrianCunningham Re: Need an LT4 Guru!
They're also nice if the spring breaks, keeps the valve out of the piston.
Posted on: 2011/7/25 1:15
God's country, Pa
197 Posts
You mean having a damper, right Brian?
Posted on: 2011/7/25 19:00
God Bless America!
MK 82 Re: Need an LT4 Guru!
Palm Beach Gardens, FL
439 Posts
It is just a second smaller spring. Never heard it called a dampner. They are not used as much anymore.
Posted on: 2011/7/28 4:28
96 CE Roadster LT4
