matts85vet | what do i need to tune my '85? | ||
i have:
laptop usb aldl cable winaldl tunerpro i need: chip burner chip eraser chips anyone know any inexpensive brands or part#'s? anything else i need? |
Posted on: 2011/8/31 20:43
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x- |
Ultraman | Re: what do i need to tune my '85? | ||
A line to Mseven (Mick) wouldn't hurt.....
Here is a post from the other day..... http://www.corvette-guru.com/modules/ ... e=&topic_id=15240&forum=1 |
Posted on: 2011/8/31 23:52
matts85vet | Re: what do i need to tune my '85? | ||
i contacted him awhile ago. he doesn't do '85's.
i guess the 85 is unique. i need a burner and an eraser that will work for the 1226870. anyone have any good used equipment? |
Posted on: 2011/9/1 2:20
captmike13 | Re: what do i need to tune my '85? | ||
I think forum member tjwong can do an 85. Would be worth contacting him. He also uses the same name on CF. He usually posts under the C6 and Pacific Northwest sections.
Posted on: 2011/9/1 10:35
Matatk | Re: what do i need to tune my '85? | ||
If I recall correctly, some guys repin the ECM and run a later year like the '165. You might have to do a little research into that.
matthew |
Posted on: 2011/9/3 1:06
383tpimachine | Re: what do i need to tune my '85? | ||
870 is terrible. I am repinning to the 165. It is worth it in the long run. Very simple.
Posted on: 2011/9/3 2:59
klkordzi | Re: what do i need to tune my '85? | ||
What changes have you made that you what to reborn a chip? The 85 is a very forgiving MAF system and my understanding is there is very little performance wise that can be "tuned".
Posted on: 2011/9/3 11:54
mistaben | Re: what do i need to tune my '85? | ||
comment deleted... wrong year car.
Posted on: 2011/9/3 19:57
