305 user(s) are online (236 user(s) are browsing Forums)
matts85vet what do i need to tune my '85?
Toledo, Ohio
58 Posts
i have:
laptop
usb aldl cable
winaldl
tunerpro
i need:
chip burner
chip eraser
chips
anyone know any inexpensive brands or part#'s?
anything else i need?
Posted on: 2011/8/31 20:43
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
Ultraman Re: what do i need to tune my '85?
14754 Posts
A line to Mseven (Mick) wouldn't hurt.....
Here is a post from the other day.....
http://www.corvette-guru.com/modules/ ... e=&topic_id=15240&forum=1
Posted on: 2011/8/31 23:52
matts85vet Re: what do i need to tune my '85?
Toledo, Ohio
58 Posts
i contacted him awhile ago. he doesn't do '85's.
i guess the 85 is unique.
i need a burner and an eraser that will work for the 1226870.
anyone have any good used equipment?
Posted on: 2011/9/1 2:20
captmike13 Re: what do i need to tune my '85?
Hillsboro Mo
2166 Posts
I think forum member tjwong can do an 85. Would be worth contacting him. He also uses the same name on CF. He usually posts under the C6 and Pacific Northwest sections.
Posted on: 2011/9/1 10:35
13 GMC 3500 dually
captmike13@yahoo.com
Matatk Re: what do i need to tune my '85?
If I recall correctly, some guys repin the ECM and run a later year like the '165. You might have to do a little research into that.
matthew
Posted on: 2011/9/3 1:06
383tpimachine Re: what do i need to tune my '85?
Corpus Christi
976 Posts
870 is terrible. I am repinning to the 165. It is worth it in the long run. Very simple.
Posted on: 2011/9/3 2:59
1970 El Camino-Awaiting LSX
klkordzi Re: what do i need to tune my '85?
Pittsburgh, Penna
152 Posts
What changes have you made that you what to reborn a chip? The 85 is a very forgiving MAF system and my understanding is there is very little performance wise that can be "tuned".
Posted on: 2011/9/3 11:54
mistaben Re: what do i need to tune my '85?
141 Posts
comment deleted... wrong year car.
Posted on: 2011/9/3 19:57
