283 user(s) are online (168 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
donhall VATS lubrication..... necessary? - 1992
297 Posts
Just spent about an hour (slow learner) reading about VATS, and did
not find a suitable lubrication for the ignition. Some posts suggested that WD40 & graphite were taboo. Some posts suggested cleaning with alcohol was sufficient.
My keys work just fine, but I ordered 2 double-sided blanks (#5 ) for 3.25/ea., just in case.
My ignition and keys are 20 years old. Should the mechanism and keys be lubricated?
Posted on: 2012/10/8 2:13
1Fast04Vert Re: VATS lubrication..... necessary? - 1992
Not with any lube that leaves a residual of any kind, which really means no lube. I have sprayed a little electrical
contact cleaner in the key slot and wiped the key pellet with brake clean, but that is about all.
Posted on: 2012/10/8 2:21
donhall Re: VATS lubrication..... necessary? - 1992
297 Posts
Thanks, Andy....... I see the key word is 'pellet' that should be cleaned.
Posted on: 2012/10/8 2:32
Matatk Re: VATS lubrication..... necessary? - 1992
Use some rubbing alcohol or contact cleaner on the key.
On a somewhat related note, Brad was having a problem turning the lock cylinder and found out this good piece of advice:
http://www.corvetteguruforum.com/modu ... hp?topic_id=17415&forum=1
Posted on: 2012/10/8 3:00
297 Posts
Thanks, Matthew....... I remember reading that thread, but forgot about it. Reading the reviews of customers using the product from HD, some say the locks became 'frozen' after applying graphite.
Posted on: 2012/10/8 4:16
That's interesting...maybe they used too much graphite? I can't really say.
Posted on: 2012/10/8 11:37
BillH Re: VATS lubrication..... necessary? - 1992
I'm really big on preventive maintainence.
BUT some things like VATS, fall under "If it ain't broke, don't fix it".
Lubing the ign. switch is not a good idea.
Posted on: 2012/10/8 13:36
SJW Re: VATS lubrication..... necessary? - 1992
Central Maryland
51 Posts
I got into the habit years ago of wiping both sides of the ignition key on my pants (unless they're sweaty or grungy!) before inserting the key into the lock cylinder. No VATS problems so far here!
Live well,
SJW
Posted on: 2012/10/10 23:50
297 Posts
Live well,
SJW
Thanks for the info, SJW. Wonder if cords, denim, or gabardine material would make a difference?
My curiosity of wear was more towards the key 'teeth', rather than the pellets. The keys seem to last much longer than I would have anticipated. I bought two extra keys just for a 'security blanket'.
Posted on: 2012/10/11 0:58
Oh geeze...the "teeth" part of the key should last 100,000 miles. I replaced mine at 90,000 with a new one because it was showing some wear. Just make sure once you cut a new key you start using that key and use the old one as the spare.
Posted on: 2012/10/11 1:00
297 Posts
Thanks, Matthew........ I'm curious if Andy Bogus has replaced his keys
for his 'million mile' vette.
Good advice on using my new keys immediately.
Posted on: 2012/10/11 1:15
Original keys on my 95 have gone over 240,000. They just don't wear out.
Posted on: 2012/10/11 2:13
297 Posts
A new track record!
Good news, Andy.
Posted on: 2012/10/11 2:23
I wipe my key................never.
Posted on: 2012/10/11 2:31
297 Posts
Yeah, but you are in the high desert, Bill, no/low humidity.
Posted on: 2012/10/11 2:52
Doesn't matter Don.
Besides, IF you experience a VATS problem, 95% of the time,it won't be the key. And it will be rare if you ever do.
BTW, my car "grew up" in Vacaville.
Posted on: 2012/10/11 13:01
If you have a problem 95% of the time it is greasy fingerprints on the key.
Posted on: 2012/10/11 21:30
