193 user(s) are online (137 user(s) are browsing Forums)
mikemac Replacing Spark Plug Wires
Omaha
3 Posts
I would appreciate some info on the easiest way to replace spark plug wires on my 94 vette.
Posted on: 2006/7/12 0:46
bogus RE:Replacing Spark Plug Wires
pay someone.
plug wires on these are tricky... I suggest you take as much apart as you can.
There is a tricky plug wire loom under the AC compressor... I would actually remove the compressor and swing it out of the way.
I would also remove the fender covers, because that will make life easier to reach in there.
Also, if you haven't, replace the plugs at the same time (I HIGHLY recommend NGK).
What wires are you going with? Taylor or MSD are the best options.
Posted on: 2006/7/12 4:28
hulagan808 Re: Replacing Spark Plug Wires
hawaii, maui
58 Posts
I would advise anyone thinking about installing fat 8mm wires on these engines to forget it and get wires made to fit the original wire routing. can it be done? only if you have more time than brains. (dont ask how I know this) besides there are thin high perf. wires available nowadays. Aloha
Posted on: 2008/6/30 19:12
88 vert, gen 7, superram, blah blah blah for days
pianoguy Re: Replacing Spark Plug Wires
Some folks remove the power steering pulley (need a simple puller to remove). I managed by just loosening the bolts for the pump and sliding it forward a bit.
Posted on: 2008/6/30 19:19
fnsblum Re: Replacing Spark Plug Wires
Nothern Utah
32 Posts
I was able to do mine by removing the belt, idler pulley assembly and the panels over the inner control arms. Use the 8 MM wires with new looms from Autozone, Checker etc. My original looms were brittle and most broke pulling them out. If the plugs have a lot of miles this would be the time to replace them as already stated above. Later! Frank
Posted on: 2008/7/1 3:03
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
81c3 Re: Replacing Spark Plug Wires
Colorado
143 Posts
Well, I can agree & disagree....I have done LT1 plugs & wires a couple of times now. You really dont HAVE to take the PS pulley off or the compressor. The belt being removed is a big help. It can be done as it sits though. I also managed to use all the original looms . Its very time consuming & your fingers & hands will ache, but it can be done.
Posted on: 2008/7/1 4:13
BillH Re: Replacing Spark Plug Wires
8mm Taylors fit the stock looms just fine.
Posted on: 2008/7/1 13:49
The puller costs $24, so that's next to nothing compared to the time it saves, especially if you use it more than once.
It also gives you much better access to the driver's side of the opti.
Performance Tool p/n 87022 available at any PepBoys,etc.
Posted on: 2008/7/1 13:54
