180 user(s) are online (151 user(s) are browsing Forums)
rklessdriver 434 dyno results
Just got off the dyno with my new 434.
722HP @ 7000 RPM
585TQ @ 5900 RPM
I made one pull where it made 727HP but after some retuning for a better average power across the RPM range it lost a few peak horses.
We went down 2 numbers on the jets and moved the ignition advance from 36* to 38* and finally best average power came with 40*.
I had a slight issue to start the day and lost a few hrs tuning time fixing it so we didn't have time to make any "hero pulls".
The AF is super safe at 11.9 to 12.0 in the real RPM band.
These numbers are with my QFT950 carb using VP NO2 fuel.
I did make one pull with my brothers C&S Aerosol Billet dominator but it was pig rich pulling 10.0 AF and made 712HP but like I said we just didn't have the time to really tune it in and make the hero pulls I wanted.
Have video and dyno sheets I will post up when I get home Monday.
It's a bad man and I can't wait to crack open the nitrous.....
Posted on: 2014/6/13 22:48
bogus Re: 434 dyno results
That's nuts, dude! Killer nuts!!!
Posted on: 2014/6/13 23:56
pianoguy Re: 434 dyno results
Holy mackerel!!
Posted on: 2014/6/14 2:04
Matatk Re: 434 dyno results
That is incredible. Hope the rear end can handle it.
Posted on: 2014/6/14 3:06
rklessdriver Re: 434 dyno results
Here is the Dyno Sheet and graph.
Had to convert these from a PDF so not sure how well they will look..... If they lok bad I will do something else.
Also still trying to get the video uploaded from my carmera.
Posted on: 2014/6/16 18:15
BrianCunningham Re: 434 dyno results
Nice!
Posted on: 2014/6/16 22:48
Posted on: 2014/6/17 2:14
Man, that is heavenly!!
Posted on: 2014/6/17 12:53
PeteK Re: 434 dyno results
Vicious!
Posted on: 2014/8/10 13:16
