Matt26R | Rear Hub Failure | ||
A few C5 guys have reported hub failures over the past month that were exactly what I had in early May. Left rear Timken hub w/ 4-5 weekends. It didn't like the Hoosiers...
http://s33.photobucket.com/albums/d99 ... ¤t=Brakeduct006.flv |
Posted on: 2008/6/9 16:46
Special Thanks to our 2010 Sponsors: EBC Brakes, www.TPIS.com, www.redlineoil.com, and Simpson Race Products. |
Jeffvette | Re: Rear Hub Failure | ||
Yea, you did the hub in. These cars put a lot of abuse to the rear tires.
Posted on: 2008/6/9 21:54
Matatk | Re: Rear Hub Failure | ||
Why is that? Because of the rear suspension set-up? Is there a specific reason? Not being a smartass, just not knowledgeable about it Matthew |
Posted on: 2008/6/9 22:28
Matt26R | Re: Rear Hub Failure | ||
It's strange how the hub broke completely at the flange. My guess is the track(Putnam Park)was the primary reason. A few too many right turns pulling 1.6g's.(data aq.) The last 2 turns before the front straight also have some pretty good bumps that load the car up.
Posted on: 2008/6/10 13:56
So it's like a sheering force, then?
Matthew |
Posted on: 2008/6/10 14:10
BillH | Re: Rear Hub Failure | ||
No, nothing wrong with the rear suspension, even a coilover setup wouldn't change the amount of loading the rear gets. It's bascially a very heavy car (for a racecar) and the rear hub assemblies were designed for the street. When you put a set of slicks on which have a larger tire contact patch, which allows you to go faster in the corners, higher G forces in the corners put more load on the bearings. And the offset of the wider wheel and tire puts more lever action on the hubs increasing the loading. |
Posted on: 2008/6/10 14:35
Thanks!
So is there an aftermarket hub that is stronger/more capable? Matthew |
Posted on: 2008/6/10 14:57
CentralCoaster | Re: Rear Hub Failure | ||
There's a larger spindle and bearing setup, but I don't know if that will cure your type of breakage.
BTW Timken doesn't make ball bearings last I checked. It may have their name on it, but who knows where it's from. I would switch to a known quality bearing mfr first and try again. Jrriflecoach was sourcing some usa made bearings with tapered rollers, sounds like as good a time as any to switch. I think VanSteel had something available also. |
Posted on: 2008/6/10 19:01
ghoffman | Re: Rear Hub Failure | ||
Do you still have the failed part? May I have it please? I will pay for shipping, we want to do some failure analysis and see why it failed. Please call me ASAP, I am working with VanSteel on this to see that that issue goes away.
Gary Hoffman Hardbarusa.com 603-682-8073 |
Posted on: 2008/6/11 13:48
Yeah, I still have it Gary. I should have it off sometime this week. I'll ship it out to you asap. Is this address good?? Hardbar.net, LLC PO Box 10311 Bedford, NH 03110-0311 |
Posted on: 2008/6/11 17:54
I don't know about ball bearings but they make hubs according to Autozone and my receipt. I always thought of Timken as being a good ole US of A mfr. but you're probably right about where it came from, who knows?? |
Posted on: 2008/6/11 20:06
No, please ship to:
Vansteel Inc. attn Paul 12285 West Street Clearwater, Florida 33762 727-561-9199 800-418-5397 |
Posted on: 2008/6/11 21:35
Will do.
Posted on: 2008/6/12 0:49
Please email me with your info and I will send you a UPS call tag and they will come and pick it up at your place.
ghoffman@hardbarusa.com Thanks again! |
Posted on: 2008/6/12 14:45
The new HD bearings now available for immediate shipping! The fronts will be available in August.
Thanks, Gary http://hardbarusa.com/hardbar/product ... ?cPath=32&products_id=110 |
Posted on: 2008/6/12 15:04
C4forlife | Re: Rear Hub Failure | ||
Just out of curiosity what size tires are you running on your car?
Posted on: 2008/6/19 4:17
295/17 Hoosier R6's on 11" 50mm offset A molds.
Posted on: 2008/6/19 11:43
bogus | Re: Rear Hub Failure | ||
Gary,
Those look STOUT! I will be thinking that way when I replace. No question. |
Posted on: 2008/6/21 1:01
