219 user(s) are online (166 user(s) are browsing Forums)
Crazy8 Got a great surprise while swapping valve covers
Lake Worth, FL
125 Posts
Well, the factory valve covers looked like crap, so I picked up an inexpensive chrome set to replace the factory ones (I am holding onto the factory ones so I can refinish and be able to reinstall if I want). I was also leaking oil from the valve covers, so I was going to replace the gaskets anyway. When I pulled the covers off, to my surprise and delight, were Comp Cam 1.6 Roller Rockers! Now I know why the car runs a little better in the quarter on what I thought was a factory motor. I wonder what else the previous owner did to the motor. My 86 does have a Dana 44 with 3.73 gears, that was installed two owners ago.
This also came as great news to my wife, who has decided to give drag racing a try and wants to use the 86 Vette. That is what got me started on all of this, as I wanted to do a full tune-up on the Vette. Now, she is not sure if she wants to sell the 86 Vette, if she likes drag racing. Our local drag strip has a Corvette Challenge, that she would like to compete in with me. My 08 Vette might be faster, but watch, she will end up schooling me on the tree, if we get paired up together. I guess I really need to get my 86 Monte Carlo SS transmission issue sorted out, so I can have one of my family drive it to the track as a back up to when my wife bumps me out of the Corvette Challenge, I can drive in the GM Challenge.
Posted on: 2008/12/19 16:34
2008 Corvette - JSB, 3LT, Z51, NPP, U3U, A6
1986 Corvette - For Sale...PM me for info
1986 Monte Carlo SS - 400hp
2007 Dodge Charger Daytona R/T - Plum Crazy #981 of 1400
biggrizzly Re: Got a great surprise while swapping valve covers
I wonder if it has a different cam? Just for grins, I'd measure the cam lift and see if he installed an aftermarket cam in it too.
Posted on: 2008/12/19 16:39
Crazy8 Re: Got a great surprise while swapping valve covers
Lake Worth, FL
125 Posts
What would a factory early L98 run in the quarter? I am hovering at 14.0 right now. I know the 3.73 gears help quite a bit. I'd love to figure out if it has a different cam, but I don't know how to measure the cam lift.
Posted on: 2008/12/19 16:43
BrianCunningham Re: Got a great surprise while swapping valve covers
Posted on: 2008/12/19 16:58
88BlackZ51 Re: Got a great surprise while swapping valve covers
481 Posts
Was does the Monte SS have done to it?
Posted on: 2008/12/19 18:28
Lake Worth, FL
125 Posts
The Monte Carlo SS has:
Stage 2 350 crate motor by Jasper Motors, Iron Eagle SS heads, Edelbrock Air Gap intake, Holley high flow fuel pump, Holley 670cfm Street Avenger Carb, full MSD electronics
200-4R transmission rebuilt to hold 650+hp
Strange Engineering D60 rear with 3.73 gears
Racing Driveshaft & loop
Wilwood rear disc brakes
ZEX 100hp shot nitrous with twin bottles
Eibach springs
Hotchkis sway bars
Edelbrock Adj. Uppers/Boxed Lower rear control arms
Bilstein Sport Shocks
Restored interior w/ Autometer Ultra-Lite gauges
ZR-1 Replica rims
MT ET Street Drag Radials
Hurst line loc
I think that is about all...at least most of the big stuff.
Posted on: 2008/12/19 23:51
crash Re: Got a great surprise while swapping valve covers
WRIGHT CITY MO 63390
977 Posts
hmmm that sounds like it could be around 600 rwhp uh huh
Posted on: 2008/12/20 1:40
Lake Worth, FL
125 Posts
The crate motor is rated at 350hp (at flywheel). The shop that did the work figures with the long tubes, dual exhaust and the other go-fast parts installed that the motor is making close to 400hp (again, at flywheel). Add the 100 shot of spray and I am hoping to have the car in the low 13's, once I get the transmission issue sorted out. Right now, the SS is shifting way to early in 1st and 2nd (shifts at 3400rpm). Once the shop gets that cleared up, then we'll see what it will do.
Posted on: 2008/12/20 13:25
Use to own a Monte Carlo, one of the BIG ones a '74.
As heavy as it was, it my 1st HotRod.
Posted on: 2008/12/21 16:32
Matatk Re: Got a great surprise while swapping valve covers
Should run around 14.4-14.5 stock. I doubt there's a cam in there. Most likely it's the roller rockers and the gears that dropped your time.
Posted on: 2008/12/21 17:10
Notorious Re: Got a great surprise while swapping valve covers
Oh I don't know. I'd be willing to bet you serious money there's a cam in there!
Posted on: 2008/12/21 21:49
Lake Worth, FL
125 Posts
LOL!!! Yeah, I know it has a cam in there, so if Notorious bet Matatk, Notorious won. Now...I think it is a stock cam, but none the less there is some sort of cam in the car.
Posted on: 2008/12/21 23:09
Remind me not to post when you're around. You got me
Posted on: 2008/12/22 3:42
