262 user(s) are online (249 user(s) are browsing Forums)
The ...
85L98-84L83 Porting the stock crossfire intake manifold!
113 Posts
I have a stock crossfire intake manifold I will be porting, where are the water jackets running? Are they on the lower part of the runners? My plan is to open up the port to match the gasket and to remove as much material on the inside of the runners. I will also shorten the runners from the inside and cut the top of the runners open about 1/2 inch from the start of the runner from the inside. I will remove the EGR hump as well. After removing the EGR hump, is there any welding needed? I will also remove the swirl viens to aid in air flow. Any other suggestions to achieve maximum power out of this stock intake manifold?
Posted on: 2009/3/25 19:58
vetteoz Re: Porting the stock crossfire intake manifold!
Buy a Renegade ,
"give you about 50hp and 33 hp at the rear wheels."
http://www.smokinvette.com/corvetteforum/showthread.php?t=19966
Posted on: 2009/3/25 21:38
Aardwolf Re: Porting the stock crossfire intake manifold!
Fremont, WI
209 Posts
LOL
Posted on: 2009/3/25 21:45
CFI-EFI Re: Porting the stock crossfire intake manifold!
Top of Utah
372 Posts
vetteoz wrote:
Buy a Renegade ,
You forgot the 40 hp and the 16 & 22 ft.lbs. of torque. This guy doesn't know if he is afoot or on horseback.
RACE ON!!!
Posted on: 2009/3/26 18:08
85L98-84L83 Re: Porting the stock crossfire intake manifold!
113 Posts
I think you should just take it down a notch, this thread is about porting an intake. If you have experience in porting a crossfire intake you are welcome to share. It would be most helpful to stay on topic, you could always start a new topic if you wish.
Posted on: 2009/3/26 18:19
BrianCunningham Re: Porting the stock crossfire intake manifold!
doing a side-by-side comparison I assume?
Here ya go
http://www.technovelocity.com/chevyha ... t_polish/port_polish.html
With the ported manifold and a 2100 stall torque converter, I gained .35 in the 1/4 mile. I went from 15.75 to 15.4...
Posted on: 2009/3/26 18:32
113 Posts
WOW!!!!, that is some serious info. In the picture the runners look shorter on one side, it just might be me.
Would there be a benefit to cut the tops of the ports back a bit, kind of taper them so the fuel can get in easier?
The EGR, once removed did you notice anything with milege or codes or any problems?
Why did you sand blast it? To ruff it up a bit or just to clean it?
Thanks alot best write up I have ever seen.
Posted on: 2009/3/26 18:47
Not my writeup, but I'm sure you could contact him.
Posted on: 2009/3/26 19:18
CSS996 Re: Porting the stock crossfire intake manifold!
Mega Guru
Central PA
3644 Posts
CFI-EFI wrote:
vetteoz wrote:
Buy a Renegade ,
RACE ON!!!
I think a civilized debate is a good thing, but making it about the person is not cool. Let's keep it friendly, like.
Posted on: 2009/3/26 19:20
Currently "Between Vettes".
113 Posts
Any other porting experts here wanting to share? If you have ported a crossfire let it rip.
Posted on: 2009/3/26 20:54
Top of Utah
372 Posts
CSS996 wrote:
CFI-EFI wrote:
vetteoz wrote:
Buy a Renegade ,
RACE ON!!!
Apparently you haven't read his harassment, multiple claims, foolishness, slandering, and calling me a liar on another forum. He has instigated the problems and earned any hard time he can be given.
RACE ON!!!
Posted on: 2009/3/26 21:22
Mega Guru
Central PA
3644 Posts
The moderators of the other forum can deal with it as they wish. Let's do our best not to play those games over here.
I actually do not visit other sites.
Corvette-Guru is not a garbage dump for other forums.
Posted on: 2009/3/26 21:29
bogus Re: Porting the stock crossfire intake manifold!
Agreed.
Let's play nice.
CFI - I have been following this and your arguments are technically sound. You are on the right track. Please, keep it civil. The argument carries more weight that way.
Posted on: 2009/3/27 14:40
