246 user(s) are online (234 user(s) are browsing Forums)
85L98-84L83 Boob job!
113 Posts
How big to go? I figuire 500 to 550cc's will be good, that would make a large D maybe a small DD.
You can right them off on your taxes
Posted on: 2009/4/5 17:18
CSS996 Re: Boob job!
Mega Guru
Central PA
3644 Posts
Was expecting a photo...
Can't help ya. Go check Andy's other site: boob-guru.com
Posted on: 2009/4/5 18:01
Currently "Between Vettes".
redvette6spd Re: Boob job!
Minneapolis
57 Posts
Hmm well let's see
Posted on: 2009/4/5 18:23
I teach dogs to bite
www.youtube.com/watch?v=KXt8M3sissU
Durango_Boy Re: Boob job!
Who is the augmentation for? Pics? Body type should dictate the size of the breast. Too large on a small frame will look awkward. Too small on a large frame would be a waste of money.
In perspective, Audrina Patridge has around a 500cc as an example.
Posted on: 2009/4/5 18:34
BrianCunningham Re: Boob job!
I'm more of a purist, I like mother nature.
Can doc can make them look natural?
Posted on: 2009/4/6 2:24
85L98-84L83 Re: Boob job!
113 Posts
They will probably look like the picture of old sneezy you have there.
Posted on: 2009/4/6 11:59
xccter Re: Boob job!
Downtown Annapolis, MD
461 Posts
Posted on: 2009/4/6 13:10
ยด71 350/270 L48 Coupe
NCRS #48337
TommyT-Bone Re: Boob job!
CSS996 wrote: Go check Andy's other site: boob-guru.com
Ya, I'd look at a few thousand first so you can get a better idea.
Posted on: 2009/4/6 13:40
