CentralCoaster | My Corvette just got cooler. | ||
This showed up on my doorstep today.
It's a Dewitt's with built-in engine oil cooler. The core on this sucker is 2.25" thick! They say it's a direct fit, so I guess I'll find out. I have quite a bit of other work to do before it goes in, so in the meantime I might just hang it on my wall. |
Posted on: 2009/6/10 2:40
CSS996 | Re: My Corvette just got cooler. | ||
Mega Guru
Thought maybe you sold it to someone else! LOL.
That's a nice looking piece. |
Posted on: 2009/6/10 2:42
Currently "Between Vettes". |
pianoguy | Re: My Corvette just got cooler. | ||
Schweeeet! I got mine in without any real hassle, except the shroud is a PITA. The only issue I have is that there's a small tube about the size of your overflow tube that connects to a factory "T" fitting, and it fits a bit awkwardly now since the radiator is thicker. I want to figure out a way to clean that up without boogering up the "T", since it is probably a spendy piece to replace.
Posted on: 2009/6/10 3:02
movnviolation | Re: My Corvette just got cooler. | ||
Looks just like my BeCool and it was a direct bolt in for my 89. Almost to pretty to cover up!
Posted on: 2009/6/10 5:24
Mods AFR 180 comp. heads w/ heavy springs. TPIS ZZ409 cam w/ 1.6 roller rockers, TPIS long tube headers, Miniram, 52mm throttle body, 24 lb Bosch injectors, Level V TPIS chip |
Trae1976 | Re: My Corvette just got cooler. | ||
Very nice!
Posted on: 2009/6/10 11:55
Meatgrinder | Re: My Corvette just got cooler. | ||
Cool!!!!
Posted on: 2009/6/10 12:02
biggrizzly | Re: My Corvette just got cooler. | ||
Very nice! does this incoprorate both engine oil cooler and trans cooler or just the engine oil cooler?
Posted on: 2009/6/10 12:10
BrianCunningham | Re: My Corvette just got cooler. | ||
Great mod for our cars.
Real happy with the one I put in, I just wish it had an oil cooler like yours. |
Posted on: 2009/6/10 13:02
Matatk | Re: My Corvette just got cooler. | ||
Looks like a well crafted piece from the pictures.
Matthew |
Posted on: 2009/6/10 13:06
