160 user(s) are online (104 user(s) are browsing Forums)
iCorvette what is meant by over revving an engine?
302 Posts
i am not talking about sustained high rpm's just drag race type shifting.
if the engine goes to that rpm (high), and does not limit itself, like a tpi car is know for wheezing at 4800 rpms, what harm?
then aside from the weakest part, i do have some parts like the 2 bolt mains, the edlebrock roller timing chain and the vibraton damper in there stating those parts should not exceed 6000 rpm. should i excercise caution with these or is it a non issue?
is there a safety cushion when they sell this stuff,
since my stock tach is literally garbage, i have triggered the rev limiter set at 6500 once, and didn't know what it( sudden bogging)was until yesterday that the tach was too slow.
what would be my super ram optimal shift points?
any enlightenment on this would be great and thanks...
Posted on: 2009/9/21 2:20
bogus Re: what is meant by over revving an engine?
over revving is usually going to damage valves first. What happens is that the valve train is moving so fast that the valve can't close. It's called "valve float" and it's potentially bad.
Next up is the piston hitting the partually opened valve... see where this is going?
I would put in a better tach and make sure your rev limiter is accurate.
Posted on: 2009/9/21 3:15
vetteoz Re: what is meant by over revving an engine?
This test on a SR equiped 383 ( with bigger cam than yours ) shows it losing power badly past 5500 so there is little point reving higher because you will be slowing down. You will also note in the comparison ; only the HSR and MR show power gains through 6000.
http://www.compcams.com/Community/Art ... Details.asp?ID=1737510521
Posted on: 2009/9/21 5:07
iCorvette Re: what is meant by over revving an engine?
302 Posts
thanks, just what i needed
Posted on: 2009/9/21 8:24
302 Posts
since the party is over at around 5500 rpm, is it wise to set the limiter at 6000? or there about? and not go to 6500 (stock)
thanks
Posted on: 2009/9/21 8:31
sliding Re: what is meant by over revving an engine?
Zagreb, Croatia
326 Posts
Into my topic
Posted on: 2009/9/21 9:40
dan0617 Re: what is meant by over revving an engine?
thanks
Yes. I revved a stock 350 bottom end to 6200 rpm shift points for a season with no problems, but that was with an HSR intake and other supporting mods so that was about the optimal shift point for me.
For you, I'm guessing 5500 to 5800 shift points, I'd set the rev limiter around 6000 or 6200.
Posted on: 2009/9/21 12:20
As you have a manual and there is the possibility of a missed shift , I would go for the lower setting.
See sliding's posts on possible damage.
Posted on: 2009/9/21 14:18
BrianCunningham Re: what is meant by over revving an engine?
overrev and LT1 and you'll spin the rod bearings.
Posted on: 2009/9/21 14:42
Alcee1 Re: what is meant by over revving an engine?
Los Angeles
277 Posts
What is meant by over revving????? when you've blown your motor, you over rev'd couldn't resist.
Posted on: 2009/9/21 15:53
302 Posts
the ultimate limiter, self destruction back to 0 rpm permanently...
Posted on: 2009/9/21 16:55
302 Posts
why an lt1 and not an l98? for rod bearings that is...
Posted on: 2009/9/21 16:56
302 Posts
dan0617 wrote:
thanks
we'll i to have the arf heads with the 8mm valve stems and 8019 heavy duty springs still newish( 2800 miles), (i know my XFI cam has some steep ramps) and crane gold roller rockers 1.6, if i had a HSR , I know i don't have them, but suppose it did wouldn't these parts could support the higher rpm's correct?.
but suppose i switched to a mini ram for discussion...
would the timing chain break? and the damper grenade?
if not then an occasional miss shift may not be the "
kiss of death": am i wrong here?
i know this is moot as the power band is lower which is fine i like and need the mid and low end torque.
setting the 6000 limit now thanks gents....
Posted on: 2009/9/21 17:08
BeachBum Re: what is meant by over revving an engine?
751 Posts
Assuming you are running the set-up in your signature.... I raced a very similar set-up for many years, albeit with a different cam..... made its HP peak at 5700 rpm on the chassis dyno, and I shifted typically in the 6000-6200 rpm area..... I tried running it higher, it didn't go any faster, I did short shift it, and it would slow down a little. I would think a 6500 rpm rev limiter and shift at around 6000 rpm and then experiment.
Good Luck !
Posted on: 2009/9/22 1:45
Actually, I was under the impression it was wrist pins... there seems to be a belief that they are weak. I haven't seen enough empirical data to back it up, considering the rotating masses are nearly identical.
Posted on: 2009/9/22 2:48
sliding wrote:
Into my topic
Check.
Posted on: 2009/9/22 2:49
PeteK Re: what is meant by over revving an engine?
I have seen the wrist pins get yanked through a cast piston in a high rmp motor making decent power.
Posted on: 2009/9/22 14:28
