DrEvil | Random tech tip of the day | ||
Did you know that (at least on 96 models) if you open a door and leave it open, thus waking the CCM and turning on the interior lights they will go off after 15 minutes. But if you open the hatch and nothing else the cargo lamps will stay on as long as your battery lasts.
Posted on: 2007/12/31 7:39
1996 Coupe Hotcam, headers, true duals, 4.10s. 1969 Wife. Stock, special ordered with redhead package and ride control. 2005 Son. Order date Nov27th 2004. Build date Aug 9th 2005 . Stock with blonde hair/blue eyes and hell on wheels package. |
runner140 | RE:Random tech tip of the day | ||
On my 96', after several minutes, of the hatch being opened, the lights go off. I keep my hatch open for over an hour several times a week.
Posted on: 2007/12/31 17:17
bogus | RE:Random tech tip of the day | ||
on my 92, I don't think the hatch lights ever go off.
As an aside, if you leave your turn signals on, after about 1 miles, the headlight bonger will alert you. |
Posted on: 2007/12/31 19:02
BillH | RE:Random tech tip of the day | ||
on my 92, I don't think the hatch lights ever go off. On my 92 also, the hatch open will run the battery down. The door lites will go off like Evil's 96. |
Posted on: 2007/12/31 19:28
RollaMo-LT4 | Re: Random tech tip of the day | ||
Trivia Winner
But if you open the hatch and nothing else the cargo lamps will stay on as long as your battery lasts. Well, they go out within 10-15 minutes on my '96. So, to make sure I just went out to the garage and opened the hatch. The cargo lamps came on as expected. And within 10-15 minutes, they went out as I expected. No doors open, only the rear hatch. |
Posted on: 2007/12/31 20:33
DrEvil | RE:Random tech tip of the day | ||
Go figure, maybe some different programs in the CCM. Mine will run the battery down. The 96 FSM says thats the way its setup also.
Posted on: 2007/12/31 22:19
tomb | RE:Random tech tip of the day | ||
My 95 hatch light will stay on as long as the hatch is open. The doors go off after a while.
Posted on: 2008/1/1 15:58
Midnight85 | RE:Random tech tip of the day | ||
My 95 hatch light will stay on as long as the hatch is open. The doors go off after a while. Same here on my '85. |
Posted on: 2008/1/1 16:12
HORSEPOWER! Some is good, more is better, too much is just right. |
C4DERF | RE:Random tech tip of the day | ||
:me2: doors lights go off after 10 minutes or so, hatch lights stay on till closed or battery is drained, the under hood lights act like the hatch lights so I modified them and installed a switch after the fused link. Calls for a pic:
Posted on: 2008/1/1 16:43
94 C4 LT1 A4 Polo Green w/Lt Beige Coupe Can I join the 600 club???? I can only round up 598 at present! :book: [IMG]http://i151.photobucket.com/albums/s150/c4derf/CasualCorvettes-SonicAug07011.jpg[/IMG] |
SpeedHound | RE:Random tech tip of the day | ||
Weird. My 96 bird will turn the lights off with the hatch up only.
Posted on: 2008/1/3 2:33
EcoVette | RE:Random tech tip of the day | ||
on my 92, I don't think the hatch lights ever go off. Same on the 94, freaked me out when I heard it gong. Thought it was in the music at first. |
Posted on: 2008/1/3 17:36
Its like DajaVu all over again |
apeacefulstorm | RE:Random tech tip of the day | ||
15 minutes here (93 ruby) and lights will go off.... just like turning off the car and the radio stays on for 15 minutes or when the door is opened...
Posted on: 2008/1/4 3:22
"I have the need, the need for speed...." |
dan0617 | RE:Random tech tip of the day | ||
:me2: doors lights go off after 10 minutes or so, hatch lights stay on till closed or battery is drained, the under hood lights act like the hatch lights so I modified them and installed a switch after the fused link. Calls for a pic: Dude, that's awesome. I'm thinking of installing some sort of timer on mine, but a switch will do if I don't come up with something. Any idea what color wire I should be looking for or where on an '89 vert? I have a Chilton's, I'll have to look through it some and see if it shows up on a wiring diagram to point me in the right direction. |
Posted on: 2008/1/4 14:59
