CentralCoaster | Tire Review: Kumho Ecsta XS | ||
Cliff notes: DO NOT BUY THESE.
I bought these tires in June, <5000 miles ago and they are already down to the wear bars. I have no track reviews because they didn't last long enough to make it to the track. This is 100% street driving with 1 short burnout. They are soft, but I don't see the point. I've had other tires just as sticky that made it to 8000-10K miles including track time. The treadlife on these is comparable to living next door to John Force with him having a key to your car. |
Posted on: 2009/11/16 23:24
BillH | Re: Tire Review: Kumho Ecsta XS | ||
So, what are you going to try next?
Posted on: 2009/11/16 23:38
BrianCunningham | Re: Tire Review: Kumho Ecsta XS | ||
That's good to know
I was thinking of getting those as my next street tire. |
Posted on: 2009/11/17 0:29
Ultraman | Re: Tire Review: Kumho Ecsta XS | ||
I have a couple of thousand miles on a set I bought in early Sept. They are the all season version since I knew there would be no track time. I like them a lot. They are quiet and go around our one curve real well. Mine cost about $128 each. I've been recommending them. Only 2K miles though. I will watch them closer. Ecsta ASX. They had a fair review on Tire Rack and a hell of a good price.
Posted on: 2009/11/17 0:48
bogus | Re: Tire Review: Kumho Ecsta XS | ||
I have the same tires, CC, and they are wearing perfectly fine.
Put them on in May and have added about 3k miles since. |
Posted on: 2009/11/17 2:54
Curtis1974 | Re: Tire Review: Kumho Ecsta XS | ||
I Have Kumho Ecsta STP's on the '74 and the tires in the front have worn down considerably and have maybe less then 3,000 miles on them. However, the car is need of a serious alignment and needs the cambers adjusted. This probably has not aided in the life of these but damn! I do however like the aggressive look but next time I'm going after a set of these
BF Goodrich G-Force KDW's |
Posted on: 2009/11/17 13:35
I'm fairly sure that's what I'm going to try next too. My 92 came with KDWS (different tire, M&S). 25k and 1 1/2 hrs. track time with a boatload of tread left. Not that great at the track but very good in the wet. |
Posted on: 2009/11/17 14:08
CentralCoaster | Re: Tire Review: Kumho Ecsta XS | ||
All Kumho's aren't created equal guys. It'd be like comparing a Chevy Box van to a Camaro.
The Ecsta XS is their softest "street" tire compound. I've had success with other Kumho tire models, but won't be buying this one again. |
Posted on: 2009/11/17 22:42
Looks like you got yours on about a month before I did. Let me know how they work out for you. I have really taken it easy on these tires, moreso than any I've run in the past. I'll probably try the Nitto NT-05 next. |
Posted on: 2009/11/17 22:46
RIISITAS | Re: Tire Review: Kumho Ecsta XS | ||
I had great luck with the KDWS too. Looks like they're out of production now though... I would have bought another set. |
Posted on: 2009/11/30 0:40
I think the KDWS are still around, it's just that BFG is a batch manufacturer, so they may just need to ramp up a new batch.
Posted on: 2009/11/30 2:00
TireRack has both 17in sizes in stock. The only thing I don't like about them is that they are noisy on concrete. |
Posted on: 2009/11/30 14:20
Just checked Tire Rack again for BFG KDWS 255/45R17 and 285/40R17. Came up dry... They did have other tires in that size though. If you have a link for Tire Rack with those tires in that size send it to me. Curiously there seems to be a small selection in those sizes...
Posted on: 2009/12/1 7:37
You're right, sorry. I looked a little too quick at the sizes.
And the selection does bite. |
Posted on: 2009/12/1 14:29
