292 user(s) are online (257 user(s) are browsing Forums)
Jeffvette Fuel pump issue
Not sure what the problem is here. See anything that is obvious? LOL.
Posted on: 2009/12/29 1:48
CentralCoaster Re: Fuel pump issue
I'd hate to see what the entire cooling system, brake lines, and fuel lines look like.
Posted on: 2009/12/29 3:19
j3studio Re: Fuel pump issue
Wow...
...scary.
Posted on: 2009/12/29 4:19
Matatk Re: Fuel pump issue
Yeah. No fuel tank. Duh. Everyone knows you can't pump fuel if there isn't any.
Posted on: 2009/12/29 12:29
TommyT-Bone Re: Fuel pump issue
Where was that stored; under a BBQ stove?
Posted on: 2009/12/29 12:55
BrianCunningham Re: Fuel pump issue
LOL
well you could try setting in on fire
works for the BBQ
couldn't hurt at this stage.
Posted on: 2009/12/29 13:57
bogus Re: Fuel pump issue
since when did the fuel tank store washer fluid?
Posted on: 2009/12/30 17:00
flyboy Re: Fuel pump issue
...new-fangled grill igniter.
Posted on: 2009/12/30 17:04
