254 user(s) are online (227 user(s) are browsing Forums)
Driver Information Center.
movnviolation What is this?
Hesperia, Calif
188 Posts
[IMG]http://i22.photobucket.com/albums/b318/movnviolation/Vacuumleak003.jpg[/IMG]
I have been suspecting a vacuum leak for some time but could not find one. I took my car, an 89 heavily modded, down off the ramps and then found this on the floor under the car. It must have dislodged as the car was tweeking getting it down. The location was left side rear of engine. I have a pencil pointing at a broken nipple. Any help as to what this is and original location would be a great help.
Thanks
Posted on: 2010/3/14 7:43
Mods
TommyT-Bone Re: What is this?
Guess. Maybe the check valve on the brake booster.
Posted on: 2010/3/14 9:11
movnviolation Re: What is this?
Hesperia, Calif
188 Posts
Posted on: 2010/3/14 9:13
Mods
lindenbob Re: What is this?
Pa
16 Posts
Yes that is a check valve. I would suspect for the cruise control or heater/ac. Without it you definately have a vacuum leak. I am not an L98 person but on the LT1 it is located under the fuel rail cover. Local auto parts stores normally stock these.
Posted on: 2010/3/14 9:19
Hesperia, Calif
188 Posts
Don't know why link does not work, but it is the heater/ac valve. Thanks
Posted on: 2010/3/14 9:24
Mods
pianoguy Re: What is this?
You should be able to pick one of those up for just a few bucks at NAPA, O'Reilly, Autozone, etc.
Posted on: 2010/3/14 16:55
Tre57 Re: What is this?
Portland, OR
104 Posts
Yep, I picked one up at NAPA a couple weeks for about $5.
Posted on: 2010/3/14 18:06
93 AT Coupe
Actually, mine cost $202 at NAPA, but it came with a free low-profile floor jack.
Posted on: 2010/3/14 19:48
bogus Re: What is this?
yea, Brad... My car was free, but the key cost $16k.
but yes, that's the check valve for the AC system. Should be on the right of the engine.
Posted on: 2010/3/14 20:29
Matatk Re: What is this?
Hehe...story of my life.
Posted on: 2010/3/14 20:43
vetteoz Re: What is this?
No vac leaks , just means your vent positions will change every time you accelerate as engine vac changes.
Side port goes to a "T" where it splits to cruise and to hard line on inner wheel well to vac ball under drv side headlight
[IMG]http://i171.photobucket.com/albums/u309/vetteoz/checkvalve.jpg[/IMG]
Posted on: 2010/3/15 1:52
Hesperia, Calif
188 Posts
Thanks all!
Posted on: 2010/3/15 2:20
Mods
