186 user(s) are online (74 user(s) are browsing Forums)
captmike13, more...
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
BillH Distributor Rebuild
Rebuilt the distrubutor, it was rusty, the shaft was locked in, weights wouldn't move.
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0876.jpg[/IMG]
Soaked the shaft overnite in PB just to get it out, forgot to take a before pic, it was black with goo.
After cleaning:
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0878.jpg[/IMG]
Housing after cleaning:
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0884.jpg[/IMG]
The deap cavity around the bronze bushing gets filled with grease.
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0886.jpg[/IMG]
Clean parts:
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0888.jpg[/IMG]
Points cam was polished on a buffer to reduce point block wear:
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0890.jpg[/IMG]
Shaft/bushing play checked on both ends, less than .002
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0899.jpg[/IMG]
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0907.jpg[/IMG]
Bushing cavity filled with grease and cap installed:
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0908.jpg[/IMG]
Done, with correct metal band showing part number and build date. I still have to get a correct vacuum advance.
[IMG]http://i830.photobucket.com/albums/zz223/Billhet/IMGP0912.jpg[/IMG]
Posted on: 2010/7/19 22:47
BrianCunningham Re: Distributor Rebuild
be nice to see your midyear back on the road.
Posted on: 2010/7/19 22:58
Matatk Re: Distributor Rebuild
22996 Posts
Looks good, Bill.
Posted on: 2010/7/20 1:58
flyboy Re: Distributor Rebuild
Nice attention to detail.
Posted on: 2010/7/20 2:32
BillH Re: Distributor Rebuild
I'd rather see my racecar back on the track, but...
Thanks guys, once you get past the rust, it's fun.
Posted on: 2010/7/20 12:44
teebee Re: Distributor Rebuild
12826 Posts
It's a labor of love, Bill. And I'm sure that when you get it all back together, it will be great.
Posted on: 2010/7/20 22:48
Trae1976 Re: Distributor Rebuild
Johnson City, TN
832 Posts
Nice work Bill!
Posted on: 2010/7/21 13:38
