206 user(s) are online (172 user(s) are browsing Forums)
Driver Information Center.
JeffK Stupid question - is this an aftermarket chip? pics inside
High Point, NC
1440 Posts
The guy that I bought the car from told me that it had a chip in it so I decided to check it out last night.
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/SU1HMDAwNjctMjAxMDA5MDctMTg0Ny5qcGc.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/SU1HMDAwNjgtMjAxMDA5MDctMTg0Ny5qcGc.jpg[/IMG]
I have never put a chip in any car so I'm not sure what I'm looking at.
Thanks,
Jeff
Posted on: 2010/9/8 12:12
Mekanic Re: Stupid question - is this an aftermarket chip? pics inside
Tampa Bay Florida
827 Posts
Looks stock to me. Unless he had it tuned by someplace that didn't add a sticker.
Most add a sticker.
Posted on: 2010/9/8 13:00
~Rich
Polo LT4
JeffK Re: Stupid question - is this an aftermarket chip? pics inside
High Point, NC
1440 Posts
That's what I thought.
Posted on: 2010/9/8 13:02
mseven Re: Stupid question - is this an aftermarket chip? pics inside
Motor City Madhouse
247 Posts
It is a stock prom, but that doesn't mean it hasn't been reprogrammed. Only one way to know for sure and that is to open it (through hardware/software) and compare it to a stock bin file.
Posted on: 2010/9/8 13:36
Steve40th Re: Stupid question - is this an aftermarket chip? pics inside
1114 Posts
There was an older tuner in Jersey that used to take the factory chip off and re-solder it to the oem housing. This may be one of those. It was Performance???? Something.
Posted on: 2010/9/8 16:20
Ko'u ohana aia ku'a ikaika
High Point, NC
1440 Posts
Well, TPIparts is not too far from me. I wonder if I can get him to look at it. I do not have the ALDL cable yet and have never worked within the ECM programming anyway so I wouldn't know what I'm doing.
Posted on: 2010/9/8 16:51
Woodstock Re: Stupid question - is this an aftermarket chip? pics inside
Bremen/Germany
369 Posts
That's a bone stock chip, not tampered with!
To erase the eprom you would have to take off the silver sticker. At least a little corner of the sticker would be bend. I doubt it would be lined up this perfect after reprogramming, the glue on the back of these stickers is not very strong, sort of "one time only sticker".
This one is stock!
Posted on: 2010/9/10 10:52
91 convertible
High Point, NC
1440 Posts
This one is stock!
Thank you!
Posted on: 2010/9/10 11:24
Matatk Re: Stupid question - is this an aftermarket chip? pics inside
22810 Posts
Here's a dumb question: where did you get that chip from? Was it loose in an extra parts bag, or did you remove it from the ECM?
Posted on: 2010/9/10 12:28
Motor City Madhouse
247 Posts
feel free to explain what the stcker has to due with erasing and burning.
Posted on: 2010/9/10 12:49
Bremen/Germany
369 Posts
To be honest, you should know.
To erase this type of eprom you have to use UV light!
This is not an electronic erasable eprom, the quartz under the sticker has to be exposed to let the UV rays in, that simple!
Posted on: 2010/9/10 15:05
91 convertible
High Point, NC
1440 Posts
I pulled it out of the ECM to examine it to see if it truly was an aftermarket chip.
I am going to order
http://cgi.ebay.com/ebaymotors/ws/eBa ... &ssPageName=STRK:MEWAX:IT
to get rid of the EGR and AIR stuff since my headers deleted all of that.
Posted on: 2010/9/10 15:22
Tampa Bay Florida
827 Posts
JeffK wrote:
I am going to order
You'd have a lot better success going with pcm4less
Posted on: 2010/9/10 21:42
~Rich
Polo LT4
High Point, NC
1440 Posts
It looks like pcmforless does about the same thing as tbiparts does. Except he is about 10 minutes from me and at 1/2 the price. Unless you have heard bad things about him. Plus while I'm there I can get a new map and tps connector.
Posted on: 2010/9/10 21:52
Tampa Bay Florida
827 Posts
I can't say I've ever heard bad things, I've just never heard anything at all lol. I know of tons of people who have used PCM4Less. But if you have good reports, by all means go to tbiparts
Posted on: 2010/9/11 14:00
~Rich
Polo LT4
anesthes Re: Stupid question - is this an aftermarket chip? pics inside
Boston, MA
They're both going to do the same thing.. Change a few constants and take your money..
I don't know what year car you have, but that memcal is out of a '90+. The circuit is for the knock sensor, which was moved from a firewall mounted module to a circuit on the memcal on the '727 ECM.
-- Joe
Posted on: 2010/9/14 0:58
High Point, NC
1440 Posts
I'm not looking for massive or really any performance gains. I'm just tired of seeing the SES light on for the EGR system.
Posted on: 2010/9/14 11:54
Boston, MA
Ahh. Just edit two constants, and flip a flag.
If you were local i'd burn the chip for you.
-- Joe
Posted on: 2010/9/14 14:27
High Point, NC
1440 Posts
Well, that would be awesome. If I still lived in PA we might have made that happen.
Posted on: 2010/9/14 19:37
