115 user(s) are online (71 user(s) are browsing Forums)
Dunn1 Help 86 coupe
5 Posts
Will a bad fuel pump cause code 34? And will a bad fuel pump make the computer go to limp mode?
Brian
Posted on: 2010/11/2 22:43
tjpreul Re: Help 86 coupe
A code 34 is for the MAP sensor. I would check the connection first. When this code is set a preset perameter is used by the computer.
Posted on: 2010/11/3 1:32
bogus Re: Help 86 coupe
a bad fuel pump will not cause a direct code. It might cause the O2 sensor to go into lean condition, but that's about it. Trust me, you would feel a bad fuel pump long before it goes to lean condition.
Posted on: 2010/11/3 5:12
vetteoz Re: Help 86 coupe
tjpreul wrote:
A code 34 is for the MAP sensor. .
He has a '86 so it is for the MAF
Posted on: 2010/11/3 5:28
ooh... Don't they have both, though?
Posted on: 2010/11/3 6:15
Dale1990 Re: Help 86 coupe
Conway, AR
128 Posts
86 is MAF only.
I'd start by checking that it is plugged in properly and that there is no corrosion on the terminals. After that, checking the MAF relays would be my next step. If you have a factory service manual, I believe there are diagnostic charts for checking the relays.
Posted on: 2010/11/3 13:41
86 Coupe: SR 383
90 Convertible: Stock L98
06 Z06: Stock LS7
Dale1990 wrote: If you have a factory service manual, I believe there are diagnostic charts for checking the relays.
http://www.batee.com/corvette/codes/index.htm
Posted on: 2010/11/3 13:57
CentralCoaster Re: Help 86 coupe
a bad fuel pump can cause any number of junk codes to occur while the engine is stumbling and running like ass. If it trips with any consistency though, I doubt it's the fuel pump.
Posted on: 2010/11/4 0:15
Dunn1 Re: Help 86 coupe
5 Posts
Thanks for the info guys. The MAF sensor was bad.
Thanks for all the help!!
Brian
Posted on: 2010/11/4 12:04
WW7 Re: Help 86 coupe
Almost Heaven WV
268 Posts
I just had to replace my MAF sensor also, here is the site address for the cheapest remanufactored one I could find. It also has a year warranty on it.They also sell rebuilt ECMs for $75.00 for Corvettes.Check it out..WW
http://www.autoecms.com/?gclid=CLWT873p7qQCFU465QodQibZ1Q
Posted on: 2010/11/4 13:47
