Dunn1 | Help 86 coupe | ||
Will a bad fuel pump cause code 34? And will a bad fuel pump make the computer go to limp mode?
Brian |
Posted on: 2010/11/2 22:43
tjpreul | Re: Help 86 coupe | ||
A code 34 is for the MAP sensor. I would check the connection first. When this code is set a preset perameter is used by the computer.
Posted on: 2010/11/3 1:32
bogus | Re: Help 86 coupe | ||
a bad fuel pump will not cause a direct code. It might cause the O2 sensor to go into lean condition, but that's about it. Trust me, you would feel a bad fuel pump long before it goes to lean condition.
Posted on: 2010/11/3 5:12
vetteoz | Re: Help 86 coupe | ||
tjpreul wrote: He has a '86 so it is for the MAF |
Posted on: 2010/11/3 5:28
ooh... Don't they have both, though?
Posted on: 2010/11/3 6:15
Dale1990 | Re: Help 86 coupe | ||
86 is MAF only.
I'd start by checking that it is plugged in properly and that there is no corrosion on the terminals. After that, checking the MAF relays would be my next step. If you have a factory service manual, I believe there are diagnostic charts for checking the relays. |
Posted on: 2010/11/3 13:41
86 Coupe: SR 383 90 Convertible: Stock L98 06 Z06: Stock LS7 |
http://www.batee.com/corvette/codes/index.htm |
Posted on: 2010/11/3 13:57
CentralCoaster | Re: Help 86 coupe | ||
a bad fuel pump can cause any number of junk codes to occur while the engine is stumbling and running like ass. If it trips with any consistency though, I doubt it's the fuel pump.
Posted on: 2010/11/4 0:15
Dunn1 | Re: Help 86 coupe | ||
Thanks for the info guys. The MAF sensor was bad.
Thanks for all the help!! Brian |
Posted on: 2010/11/4 12:04
WW7 | Re: Help 86 coupe | ||
I just had to replace my MAF sensor also, here is the site address for the cheapest remanufactored one I could find. It also has a year warranty on it.They also sell rebuilt ECMs for $75.00 for Corvettes.Check it out..WW
http://www.autoecms.com/?gclid=CLWT873p7qQCFU465QodQibZ1Q |
Posted on: 2010/11/4 13:47
