104 user(s) are online (80 user(s) are browsing Forums)
iCorvette where can I get front poly shock bushings?
302 Posts
mine are toast, any links?
Posted on: 2010/12/6 16:39
tjpreul Re: where can I get front poly shock bushings?
Posted on: 2010/12/6 17:12
iCorvette Re: where can I get front poly shock bushings?
302 Posts
dude, they are beautiful, but too rich for my wallet, besides I have fx3, but I took off the actuators, if that makes a difference I don't know.
can i use sway bar link bushings in lieu of rubber?
Posted on: 2010/12/6 17:23
bogus Re: where can I get front poly shock bushings?
If you have access to a small lathe, anything is possible.
Posted on: 2010/12/6 21:00
302 Posts
I have nothing
Posted on: 2010/12/6 21:32
Well... I do. Just don't have the material.
I need dimensions and some material and I could easily make a few of those.
Posted on: 2010/12/6 21:47
1Fast04Vert Re: where can I get front poly shock bushings?
Did you check Bilstein's website and contact them?
Posted on: 2010/12/6 23:09
vis_croceus Re: where can I get front poly shock bushings?
VA
260 Posts
Posted on: 2010/12/7 2:39
94 vert
CentralCoaster Re: where can I get front poly shock bushings?
I put energy susp in the front, upper and lower. I may have use some universal ones in the lowers. Sway bar end links are much smaller
Posted on: 2010/12/7 3:03
302 Posts
thanks as always
Posted on: 2010/12/7 3:32
