iCorvette | where can I get front poly shock bushings? | ||
mine are toast, any links?
Posted on: 2010/12/6 16:39
tjpreul | Re: where can I get front poly shock bushings? | ||
Posted on: 2010/12/6 17:12
iCorvette | Re: where can I get front poly shock bushings? | ||
dude, they are beautiful, but too rich for my wallet, besides I have fx3, but I took off the actuators, if that makes a difference I don't know.
can i use sway bar link bushings in lieu of rubber? |
Posted on: 2010/12/6 17:23
bogus | Re: where can I get front poly shock bushings? | ||
If you have access to a small lathe, anything is possible.
Posted on: 2010/12/6 21:00
I have nothing |
Posted on: 2010/12/6 21:32
Well... I do. Just don't have the material.
I need dimensions and some material and I could easily make a few of those. |
Posted on: 2010/12/6 21:47
1Fast04Vert | Re: where can I get front poly shock bushings? | ||
Did you check Bilstein's website and contact them?
Posted on: 2010/12/6 23:09
vis_croceus | Re: where can I get front poly shock bushings? | ||
Posted on: 2010/12/7 2:39
94 vert |
CentralCoaster | Re: where can I get front poly shock bushings? | ||
I put energy susp in the front, upper and lower. I may have use some universal ones in the lowers. Sway bar end links are much smaller
Posted on: 2010/12/7 3:03
thanks as always
Posted on: 2010/12/7 3:32
