856 user(s) are online (345 user(s) are browsing Forums)
Matatk C4 Common Part Numbers
22996 Posts
Hey guys, I've decided to put together a one-stop source for part numbers. This is not a document for technical questions. This is a living document and will start out small at first, but will be expanded as we go. It may become a sticky later, depending on how big it gets. Anyone who would like to submit a part number, feel free, and I will add it to the list. Other pertinent info may also be included.
BODY PARTS & TRIM
Window regulators:
84-96 Left: 22063225
84-96 Right: 22063224
BRAKES
Boosters:
92-96: 10242104
PADS:
GM:
84-87:
88-96:
HAWK:
HPS
84-87: front HB173F.570 / rear HB112F.540
88-96: front HB111F.610 / rear HB112F.540
C5 upgrade: front HB247F.575
HP Plus
84-87
88-96 front HB111N.610 / rear HB112N.540
C5 upgrade: front HB247N.575
MASTER CYLINDERS:
ROTORS:
GM:
84-87
88-96
ENGINE ACCESSORIES / DRIVE ACCESSORIES
Tensioner:
88-91:10055897
ENGINE GASKETS
Intake Manifold:
85-91: Fel Pro MS93160 (upper/lower/tb)
85-91: Mr. Gasket 145 (upper/lower/tb 1.5")
85-91: Mr. Gasket 146 (upper/lower/tb 1.75" - big tubes)
85-91: GM 10174951 (lower gaskets only!)
85-91: GM 12508751 (upper gaskets only!)
Throttle Body:
85-96: GM 10105379 (tb to plenum)
85-96: GM 17113115 (iac/water passage/top plate)
ENGINE PARTS
Cylinder Heads:
88-91: 10088113
Intake Manifolds:
84: 14057016
84 (cali): 14085703
85: 14081004
86: 14087098
87-88: 10108517
89-91: 10066012
92-93: 12518284
94-96: 12552137
96 (LT4): 12550630
96 LT4 GM conversion: 12550631
Intake Plenums:
85-88: 10108443
89: 10108468
90-91: 10077151
Push Rods:
84-86: 14095256
87-95: 10046173
96 (LT1/4): 10241740
FLUIDS
LSD additive: 1052358
IGNITION / DISTRIBUTOR (2.383)
Capacitor and Harness (terminal block):
84-91: old #1892261 - still looking for updated #
Distributor Cap:
84-91: 19110932/1977046 AC Delco D338X
Ignition Coil:
84-91: 12498336 AC Delco D505A (old# 1985474 D531)
Ignition Control Module:
84-91: 19179581 (old#10482832) AC Delco # D1961A
Pickup Coil:
84-91: 1977207 AC Delco D1945
Rotor:
84-91: AC Delco D448X
Terminal Block (to elek pkg)
86-91: 1986260
INTERIOR
Dash bulbs:
84-88: 882 (bi-pin)
89: 7073 (xenon w/wedge base)
84+ DIC: 194
84+ directional/high beams: 74
Roof latch trim plates:
84-86E: 14049299 & 14049300
86L-88: 14089665 & 14089666
89-96: 10219601 & 10219602
Windshield Wiper Switch:
84-89: 10045832
SENSORS
U-JOINTS
GM:
Half shaft: 89049301
Drive shaft: 89049306
Neapco (brute force) - Advance Auto:
Half shaft: 2-0617BF (for aluminum/no zerk)
Drive shaft: 1-0626BF (for aluminum/no zerk)
Spicer:
Half shaft/non-greasable: 5-3615X/1350 series
Drive shaft/non-greasable: 5-3613x/1310 series
These are the part numbers for the correct pieces with zinc phosphate coating to prevent electrolysis.
Spicer Strap kits:
Series 1350 M8x1.0 part #3-70-48X
WEATHERSTRIPPING
GM:
Windshield: 10268887
Halo: 10283997
Hatch: 9768068
Door Right: 10269866
Door Left: 10269865
Links to sources/other part numbers:
www.gmpartsdirect.com
http://www.whiteracingproducts.com/in ... =index&manufacturers_id=2
http://parts-catalog.acdelco.com/catalog/catalog_search.php
http://www.autopartswarehouse.com/
Posted on: 2010/2/25 18:42
Edited by Matatk on 2014/3/17 2:33:16
BrianCunningham Re: C4 Common Part Numbers
thanks
New tech tip?
Posted on: 2010/2/25 18:45
CentralCoaster Re: C4 Common Part Numbers
The AC-Delco catalog gives you the ability to cross reference what years the parts fit.
Not all GM p/n's are listed, some have different AC-D numbers, some are the same.
Posted on: 2010/2/26 3:27
Here's the entire clutch and drivetrain:
Click for full size.
gif  clutchpartslist.gif (24.83 KB)
793_4b8740055821d.gif 795X551 px
Posted on: 2010/2/26 3:29
Matatk Re: C4 Common Part Numbers
22996 Posts
Good list to have. I'm not retyping that!
Posted on: 2010/2/26 3:31
22996 Posts
Couple additions. Feel free to add more.
Posted on: 2010/3/3 22:15
22996 Posts
This appears to be 84-88 chart, some numbers should apply to later years.
Posted on: 2010/3/24 3:56
Mekanic Re: C4 Common Part Numbers
Tampa Bay Florida
827 Posts
great list
Posted on: 2010/3/24 11:55
~Rich
Polo LT4
bogus Re: C4 Common Part Numbers
Well done!
Posted on: 2010/3/24 14:17
22996 Posts
More parts added. Feel free to submit some numbers if you have them.
Posted on: 2010/4/28 3:54
22996 Posts
Added some ignition and miscellaneous parts. Feel free to add anymore. I also made it a sticky so it's easier to find.
Posted on: 2010/10/23 18:19
NC Kid Re: C4 Common Part Numbers
North Carolina
1671 Posts
84-89 windshield wiper switch #10045832 (discontinued)
1984-1996 Right Window Regulator: 22063224
1984-1996 Left Window Regulator : 22063225
1992-1996 C4 Corvette Brake Booster: 10242104
1992-1996 Master Brake Cylinder : K213-022C
Posted on: 2010/12/31 1:35
22996 Posts
Updated!
Posted on: 2010/12/31 3:44
North Carolina
1671 Posts
1990-1996 Radiator Fan Assembly 10157958
1988-1996-
Right Hand Upper Control Arm 10258063
Left Hand Upper Control Arm 10258062
Right Hand Lower Control Arm 10098154
Left Hand Lower Control Arm 10098153
1992-1996 Lower Radiator Hose 10257252
1984-1996 Brake Light Switch 848036057
Posted on: 2010/12/31 16:04
22996 Posts
Updated with some more items.
Posted on: 2011/2/25 1:40
JeffK Re: C4 Common Part Numbers
High Point, NC
1440 Posts
Anyone have the part #'s for the fuel rail o-rings at the fuel line connections?
found a kit that contains the fuel rail o-rings
BWD # 274773
There is also a Fel-pro # that I will post as soon as I go pick it up at Advance auto.
Posted on: 2011/5/24 12:03
22996 Posts
The whole fuel line kit for 85-91 is 17111696 AC Delco 217-440.
As far as I can tell, the individual rings for the fuel feed/return lines are 22514722 (AC Delco 217-452) for all years except 85-87 where the return line is 22516256.
Posted on: 2011/5/25 1:42
22996 Posts
Vetteoz has advised me that if you're looking for third brake light replacements, the 12V JC halogen bulbs can be made to work by slightly adjusting the pins to fit in the sockets. A great alternative to the pricey stock bulbs.
Posted on: 2012/9/2 18:42
