253 user(s) are online (206 user(s) are browsing Forums)
The ...
biggrizzly Removing upper fender liner from the hood?
Has anyone removed and replaced the upper fender liners that are riveted to the hood? I want to remove mine to clean underneath them, and to spray them with the same rubberized undercoating I used on the other wheel house liners.
Do they require special rivets to replace them once I drill out the old ones?
Posted on: 2011/2/15 13:12
flyboy Re: Removing upper fender liner from the hood?
Mine are screwed. The rivets are another cost saving measure, I guess. I would hope they would be some kind of push rivets that don't have to be drilled out, but that would be asking too much, I suppose.
On the undercoating, I can see how it would improve the look, and was considering doing it on mine, but held off because I always wipe the area down and wondered if the rough finish would hold the dirt and make it harder.
Posted on: 2011/2/15 13:42
bogus Re: Removing upper fender liner from the hood?
yea, mine are screwed in, too. With big torx bolts.
Shine a light up there and see what you see.
Posted on: 2011/2/15 16:54
biggrizzly Re: Removing upper fender liner from the hood?
'94 the bean counters must have said to do away with the nice torx fasteners and use cheaper rivets! I'll take a photo later.
Posted on: 2011/2/15 17:16
pianoguy Re: Removing upper fender liner from the hood?
I would think you could replace them with nut-serts
Posted on: 2011/2/15 17:57
I don't know about that... but I'm a serta fiable nut! LOL
Here is a photo of the damn things. I never seen them before other than on this car.
jpg  fastener.jpg (124.60 KB)
342_4d5abf1121396.jpg 800X600 px
Posted on: 2011/2/15 17:59
BillH Re: Removing upper fender liner from the hood?
Yea, definately. And some chrome 10-32 screws.
Get the nut serts with the anti-rotation feature.
Posted on: 2011/2/15 20:47
Ultraman Re: Removing upper fender liner from the hood?
14760 Posts
Mine are torx heads but my car is a lot older then yours. This brings another question to mind, what are folks using to restore the original black color. Mine are real washed out.
Posted on: 2011/2/15 20:54
Do you guys know the best way for removing these rivets? I was going to drill them out, but I'm not sure that is the best way with these. They are not you standard pop-rivet.
Posted on: 2011/2/15 21:15
JeffK Re: Removing upper fender liner from the hood?
High Point, NC
1440 Posts
I glanced at mine the other day since the hood is up. They do look nasty.
Don, I think you could still just drill them out or Dremel the head off maybe?
Posted on: 2011/2/15 21:40
Well, that's done! 5 minutes with a drill and a 5/32" bit.
All kinds of dirt and crap under there though. After I clean up the hood and the fender liners I'll figure out what the best fastener will be. There is no means to get behind the hood in the are that they mount so they will need something that is inserted from the outside and will not spin. The rivets were spinning pretty good when I drilled them out too.
Posted on: 2011/2/15 22:50
nylon inserts may work.
@Marcus - I don't know what to do to restore these things. They look almost parkerized... I am replacing mine with allen heads!
Oh, as for the inner fender, cover it with black truck bed liner. Looks like a million bucks when done and super strong!
Posted on: 2011/2/15 23:35
Yeah.. what Andy said. I used the rubberized undercoating rattle cans on the few pieces I did so far and I'm not real pleased. It doesn't feel rubbery at all and actually seems a little chalky. Now this could be due to two things. 1) the cans of undercoat are about a year old, although never used
2) I took them in the house to get to room temperature before use, but the garage was pretty cold during application and they have been on the shelf in the cold garage all winter. So perhaps I degraded the materials. I'm already considering removing this stuff and using something else! ARRRGGGhhh!
I'll keep you all informed as to the progress of this side job that is now costing me time and energy.
Posted on: 2011/2/15 23:41
I mean truck bed liner:
http://www.duplicolor.com/products/truckBedCoating/
I used the big can with the roller kit. Works very nicely.
Posted on: 2011/2/16 0:51
14760 Posts
Nuts! I already had a bed liner all cut up and trying to glue the pieces on...........never mind.
What's the prep for the coating?
Posted on: 2011/2/16 1:04
good cleaning... scuff up paint... nothing all that hard. I was rather lazy doing prep, and the crap stuck anyway!
Posted on: 2011/2/16 1:05
Did it dry black? The stuff I used is kind of brownish black and very flat like "flat black" paint. I don't mind it being flat black, just not flaky!
Posted on: 2011/2/16 1:13
Well, I just did a little experiment. I took a can of Eastwood's Chassis Black spray paint and shot a coat of matte black over top of the undercoating. It hasn't dried completely but appears to have absorbed the paint and took on the real black and a much better texture than before. Maybe I'm on to something.
My uncle who owns a body shop says 3M has a nice product too. I'm going to check that one out as well.
Posted on: 2011/2/16 2:36
The hood ducts have small rectangular slot to allow a u-nut (of the type that holds the wheelhouse to the bumper) to be slipped on. The screw then goes through the same hole your rivet did and is held by the u-nut.
Yeah, some of the undercoat has a brownish tinge, depends on the brand. Good luck with painting over it (no adverse reaction). If I was doing it, the paint would melt the undercoating, ha-ha.
Posted on: 2011/2/16 2:56
on, If you want to try a 10-32 nutsert with the anti-rotation tab, I'll mail you one.
You can jury-rig a tool out of a 10-32 bolt to compress the nut sert.
Posted on: 2011/2/16 13:32
Sure... PM comin' your way! Thanks
Posted on: 2011/2/16 13:35
