190 user(s) are online (138 user(s) are browsing Forums)
TommyT-Bone, more...
Print in friendly format Send this term to a friend  Collector Edition
RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
biggrizzly Is there enough difference to replace my steering rack with Z51 Rack?
My car is a std 94 coupe, and was wondering if it would be worth changing out the steering rack to the Z51?
Posted on: 2009/10/26 16:58
BrianCunningham Re: Is there enough difference to replace my steering rack with Z51 Rack?
Late Z51 racks have the same ratio.
I'm putting a quick ratio in mine, which requires a bit of mixing parts. Newer style ends on and older style quick ratio rack.
Big difference in the ratio.
If your and autox'er it's worth it.
Posted on: 2009/10/26 17:08
CentralCoaster Re: Is there enough difference to replace my steering rack with Z51 Rack?
Worthwhile. Driving a base rack compared to my Z51 rack feels like driving a school bus.
Posted on: 2009/10/26 21:02
BillH Re: Is there enough difference to replace my steering rack with Z51 Rack?
I believe that, ny C4 feels like a schoolbus at times.
My 125 Shifter has fairly quick steering.
Posted on: 2009/10/26 21:10
biggrizzly Re: Is there enough difference to replace my steering rack with Z51 Rack?
I resurrected this thread because I don't know if I got enough information the first time around. While I have the motor out I might do this if its not too much hassle and it is a viable swap into the 1994. Brian said something about converting an old Z51 rack to a newer one by swapping out ends.
Does anyone know anything about this conversion?
Posted on: 2010/10/4 1:37
j3studio Re: Is there enough difference to replace my steering rack with Z51 Rack?
It drives like a truck anyway!
I remember the first time my wife followed the 1985 she couldn't believe how often I was moving the steering wheel...
Posted on: 2010/10/4 17:34
I never got any answers on this so I'm gonna let it fly again.
Posted on: 2011/2/27 3:10
Ultraman Re: Is there enough difference to replace my steering rack with Z51 Rack?
14758 Posts
Don I found this link which deals with an 85 wanting quicker ratio. The people who sell the quick ratio boxes should have some info on how to do the conversion, you would think. You may have seen this already.
http://forums.corvetteforum.com/c4-te ... ing-rack-replacement.html
Posted on: 2011/2/27 19:03
Yeah, I saw that one. I just had a guy from one of the NCCC clubs up in PA send me an email with the part no. I need. I got a lead from a CF guy then followed up with this guy I knew that races a 94 Corvette in NCCC AX.
"It is Rockauto part number 22128 and cost only $127.79 plus shipping. It is the part number used for a 89 Z51 car."
I will be ordering this in the next week or two and doing the change before my motor goes back in the car. There is a lot more room to work with the motor out. I'll let you guys know how it works out for me.
Posted on: 2011/2/27 19:12
My tuner is doing this swap for me.
It' a lot easier to do with the engine out.
Posted on: 2011/2/27 20:56
Stl94LT1 Re: Is there enough difference to replace my steering rack with Z51 Rack?
128 Posts
WOW, I'm surprised it's so cheap.
Posted on: 2011/2/27 21:17
That's after the core charge. Its a bit over $200 or so with the return of a good unit and I understand they will take the standard one I have for a core.
Posted on: 2011/2/27 21:29
128 Posts
OK, still not bad.
Posted on: 2011/2/27 21:32
Uhhhhh yeah, but who's rebuilding that rack?
Posted on: 2011/2/28 2:15
What rack? The one going back? You got me hangin' Who?
You talkin' about the new rebuiit unit? I forgot, I'll have to go look. You have some experience with bad racks?
Posted on: 2011/2/28 3:04
klkordzi Re: Is there enough difference to replace my steering rack with Z51 Rack?
Pittsburgh, Penna
152 Posts
I have an 85 and replaced the rack last year. I looked at one from Rock Auto but went through Autozone. Ease of returning the old rack for the core charge made up my mind. I went with the "sport" rack which is 2 turns lock to lock. It was a direct replacement to the old rack and everything bolted up.
Posted on: 2011/2/28 10:44
