125 user(s) are online (102 user(s) are browsing Forums)
Does it work?
TommyT-Bone Adding Water To Your Battery
33786 Posts
Posted on: 2010/12/8 21:44
tjpreul Re: Adding Water To Your Battery
Buy a maintenance free battery.
I did have an electric forklift at a job. The levels had to be checked everyday before it was put on the charger. There were days that over a gallon of water was needed. We used tap water and never had a problem.
Posted on: 2010/12/8 21:54
TommyT-Bone Re: Adding Water To Your Battery
33786 Posts
Golf cart batteries,6 per cart. Not gonna change them out. Not till I'm a billionaire.
Posted on: 2010/12/8 22:17
BillH Re: Adding Water To Your Battery
I fill mine with beer.
Posted on: 2010/12/8 23:25
bogus Re: Adding Water To Your Battery
I don't fill mine. They are maintenance free. So there.
Posted on: 2010/12/8 23:35
33786 Posts
Why not use the afterproduct? Processed beer ....
He's drinking dark beer.
Posted on: 2010/12/8 23:37
I have some lithium ion batterys that are filles with....lithium ions.
Posted on: 2010/12/8 23:40
33786 Posts
How about your meds? Lithium?
Posted on: 2010/12/8 23:47
CentralCoaster Re: Adding Water To Your Battery
No such thing as a maintenance free motorcycle battery.
Posted on: 2010/12/9 1:44
Ultraman Re: Adding Water To Your Battery
14768 Posts
Amen to that!
Posted on: 2010/12/9 3:08
benny42 Re: Adding Water To Your Battery
Houston, Tx
91 Posts
Waste of beer man. There are better uses for even
cheap brew
Posted on: 2010/12/13 4:32
We should hang out then, because I chug battery acid.
Posted on: 2010/12/13 4:48
85RedSled Re: Adding Water To Your Battery
Jacksonville, FL
57 Posts
You can still add water to most "maintenance free" batteries unless there isnt actually any cap. And yes MF batteries will need water too. Ive done it plenty of times. IMO all MF means is its gonna fail unless you keep and eye on the water.
Posted on: 2011/4/3 18:05
1985 4+3 Coupe, Bright Write me a ticket RED
33786 Posts
I just checked the water in my MF Die Hard Gold in the Yukon. 5 cells were fine one needed just a splash. I figured why would they have caps if they didn't want me to check them.
Posted on: 2011/4/3 18:11
This is an older thread, but now there are maintence free motorcycle batteries. They are using lithium ion.
My latest maintenence free is an optima. It has no caps.
Posted on: 2011/4/3 19:21
Some of the new RC lithium ion batteries are impressive, probably as much current handling ability as your car battery with a few packs in parallel. There's a vid on youtube of them starting a dragster with one.
http://www.youtube.com/watch?v=OQ8RzIBTmKI&feature=player_embedded
But I'd be concerned about charging them. You need a controller that can ensure they aren't overcharged or overvoltage, and preferrably a low voltage cutoff. That and they are more dangerous and sensitive to heat than a lead acid.
more info: http://www.bigsquidrc.com/rc-myths-fa ... iction-lipo-car-starting/
BTW, my motorcycle battery looks like it's boiling, or at least fizzing during a charge, is that normal?
Posted on: 2011/4/4 19:16
I'd say yes. I always saw bubbles in the bike batterys I charged when I was working in the bike shop. Car batteries too.
That was quite a while ago, but I don't think things have changed that much.
Posted on: 2011/4/4 20:55
