132 user(s) are online (81 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
TommyT-Bone A/C compressor / clutch question .....
33800 Posts
I started the 91 to move it. When I pressed the A/C button and it started squeeling then smoke poured out from under the hood. Upon inspection I see that the soft rubber ring has melted inside the pulley wheel and the outside metal ring now has a lot of play. The wheel no longer engages to the pulley when I hit turn the switch on. Black goop is present that leaked out from the back of the black soft rubber ring. Thoughts ..... Compressor? Clutch?
Posted on: 2011/4/13 21:08
Matatk Re: A/C compressor / clutch question .....
22810 Posts
Posted on: 2011/4/13 21:31
TommyT-Bone Re: A/C compressor / clutch question .....
33800 Posts
I just saw compressors w/clutch (oem) on ebay for $470. I was gonna jump the gun but guess I'll find out what's wrong before I jump. I'll report my findings.
Hey BillH. Did you get your winter A/C clutch issue fixed this winter?
Posted on: 2011/4/13 22:03
BillH Re: A/C compressor / clutch question .....
Aaa, the last time I mentioned my a/c clutch was like 4 years ago. Sure you mean me?
My clutch squeals when blipped off of idle but works OK on the road. I really don't use the a/c here muck.
The squeal is due to the clutch having too much of a gap.
I used to know an a/c parts website, but would have to search for it now.
Posted on: 2011/4/13 22:16
33800 Posts
No worries Bill. You know I'M not gonna be working on it.
I'll let y'all know the findings. It's gonna cost me for an hour and a half of labor or so I figure.
Posted on: 2011/4/13 22:20
Guess I should have read Matt's thread first.
I musta lost my winter "to do" list.
33800 Posts
Posted on: 2011/4/13 22:22
tjpreul Re: A/C compressor / clutch question .....
The front pulley comes off pretty easy in order to check the compressor. Mine ended up being a bad coil, that melted my outer pulley. I would almost lean towards the compressor, since the belt was sqealing. To me this would mean their was a bigger load on the belt than there should have been.
Posted on: 2011/4/14 0:45
bogus Re: A/C compressor / clutch question .....
When ordering bits, check for parts optimized for R134... unless there is a stash of R12 in Miami I am unaware of, that is.
Posted on: 2011/4/14 0:47
22810 Posts
There are lots of stashes in Miami...but I digress...
Tommy, are you able to pull the pulley off yourself and check?
Posted on: 2011/4/14 1:43
33800 Posts
Here's a tidbit from our friends at the other place.
This sounds like mine ....
A/C clutch or the bearings will leak out some nasty black stuff that makes a mess under the hood when the clutch bearings finally die.
http://forums.corvetteforum.com/c4-ge ... n/2814267-a-c-clutch.html
Posted on: 2011/4/14 11:45
33800 Posts
If you remember, last week I cleaned up the engine bay. Could this be a coincidence? I suspect that some moiture may have collected and possibly "locked" something up. No, I did not hammer the pulley area with a water stream but there was water ..........
Posted on: 2011/4/14 11:53
Nope.
Posted on: 2011/4/14 13:54
33800 Posts
Compressor failure is the verdict. New one ordered with clutch. Won't get it fixed till the end of next week after the part comes in. I will never - ever go through another summer in a car with no A/C in SoFlo. Matter of fact, I better get some driving in the next couple of months before monsoon season begins.
Posted on: 2011/4/14 23:24
1Fast04Vert Re: A/C compressor / clutch question .....
If the compressor seized then metal went thru the system. Unless you want to take a chance on doing it over again real soon make sure to change the drier or acculator, and have a nitrogen flush done.
Posted on: 2011/4/14 23:39
22810 Posts
And replace the orifice tube, too. There are several types of flushes, I can't comment on which is best.
Posted on: 2011/4/15 2:26
33800 Posts
I agree with both of you according to what I've read. If your already in that deep might as well do it right.
Posted on: 2011/4/15 2:39
jmartynuska Re: A/C compressor / clutch question .....
Rindge, NH
51 Posts
Where did you get the compressor? Same thing here, compressor failure. Pulled the orifice tube, full of metal shavings
Posted on: 2011/4/27 15:37
'89 Z51/'02 Z06
45/145BS NER SCCA
