195 user(s) are online (134 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
flyboy Loose door panel fix
I had tried double faced tape and auto glass ribbon sealer to hold the loose/warped upper front of the door panels to no avail. I finally took the plunge and screwed them in. I used the same oval head captive washer screws that are used on the rest of the panel. First making sure there was something to screw into, I drilled pilot holes appropriately spaced. The drill dia. is crucial as the SMC is all that's holding the threads. I used a 3/32". I put a gob of silicone sealant between the panel and door at the pilot hole and gently snugged down the screws. They blend in O.K. and are only seen when the door is open.
jpg  P1010002.JPG (126.75 KB)
1735_4dc989c7a07c9.jpg 640X480 px
jpg  P1010004.JPG (125.50 KB)
1735_4dc989dab33ef.jpg 640X480 px
jpg  P1010008.JPG (126.96 KB)
1735_4dc989f214e3e.jpg 640X480 px
jpg  P1010009.JPG (148.06 KB)
1735_4dc98a0ca9b82.jpg 640X480 px
Posted on: 2011/5/10 18:56
bogus Re: Loose door panel fix
I have done the same thing up there. I need to do the bracket fix that CorvetteRonW showed a few weeks back.
Posted on: 2011/5/10 21:17
pianoguy Re: Loose door panel fix
Looks good. The door panels are definitely a weak spot on these cars.
Posted on: 2011/5/10 21:40
Matatk Re: Loose door panel fix
That looks factory. Where did you pick up the screws?
Posted on: 2011/5/10 23:20
TommyT-Bone Re: Loose door panel fix
33770 Posts
It's one of those "if you don't tell em nobody will notice fixes". Looks great.
Posted on: 2011/5/10 23:26
flyboy Re: Loose door panel fix
Thanx. Corvette Central has a great selection. #344142 door panel trim screws 16pcs. $5.50. Hate to pay shipping but I haven't found this particular style at the local parts stores.
Posted on: 2011/5/11 0:13
Epimax Re: Loose door panel fix
Wilmington, NC
1814 Posts
Great Job!
Printed for reference!
I need to do the same with mine..
Posted on: 2011/5/11 14:01
