286 user(s) are online (240 user(s) are browsing Forums)
JeffK Ported SLP Runners
High Point, NC
1440 Posts
Bought these off a guy on TGO.
They were Mega ported by Corvetteplenum.com
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1305575333.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1305575335.jpg[/IMG]
[IMG]http://i149.photobucket.com/albums/s46/kresge1975/1990%20Corvette/1305575337.jpg[/IMG]
He didn't send all of the hardware but I will get some Stainless allens to match the rest of my stuff.
Posted on: 2011/5/16 20:23
rklessdriver Re: Ported SLP Runners
I like how they siamesed them 1 1/2" to 2" off the plenum... Should extend your top end power a bit.
Posted on: 2011/5/17 0:25
bogus Re: Ported SLP Runners
those look serious.
Posted on: 2011/5/17 1:32
Matatk Re: Ported SLP Runners
Looks like a nice job. A lot more chopped away than my home done version
PS - you can either make your own gaskets or get the Mr Gasket big tube runner gaskets - see my old post about that. Also, the allen cap bolts make install soooooo much easier.
Posted on: 2011/5/17 1:43
JeffK Re: Ported SLP Runners
High Point, NC
1440 Posts
Matthew, can I get those allen screws from somewhere or did you pick them up at a hardware store?
Do you still have the big runner gasket part #?
Thanks,
Jeff
Posted on: 2011/5/17 1:52
The allen bolts were originally supplied by SLP. But you can get a set on ebay for around $30.
The Mr Gasket set is 146.
Posted on: 2011/5/17 2:12
High Point, NC
1440 Posts
Thanks, just got the bolt kit off ebay. I will order the gasket set when I order the intake manifold gaskets.
I wonder if the runners will fit with my tall valve covers.
Posted on: 2011/5/17 2:38
Mine fit the edelbrocks I have, but they aren't tall. It will probably make it harder to put the bolts in/tighten them with the valve covers on.
Posted on: 2011/5/17 11:38
Ultraman Re: Ported SLP Runners
14750 Posts
I keep missing stuff. Jeff what did you finally do for your engine choice? I gotta start looking for top end breathing parts also. Is SLP better than the TPiS stuff?
They look good Jeff!
Posted on: 2011/5/17 11:58
flyboy Re: Ported SLP Runners
Cool, doesn't look like a whole lot of gasket contact area left there.
Posted on: 2011/5/17 12:56
High Point, NC
1440 Posts
I think once I get all the black RTV off there will be more contact area showing.
They have a blast cabinet at Mom's work, will it hurt the aluminum to sandblast the paint off?
Posted on: 2011/5/20 12:07
14750 Posts
I think bead blasting would give you a nicer finish but may be wrong. Sand can be more coarse. Something I remember from the old days. may not matter.
Posted on: 2011/5/20 13:26
BillH Re: Ported SLP Runners
Won't "hurt" the aluminum (unless the operator doesn't know what he's doing, too much air press, staying on one spot,etc.).
Glass beads will leave a much better surface finish, plastic media would be even better.
A bead cabinet is one of the best things I have in my shop, cheap too.
Posted on: 2011/5/20 13:54
High Point, NC
1440 Posts
I would be using the blaster. I think it's sand, it's been awhile since I worked there. They do mostly aluminum parts so it might be beads. I will check.
Otherwise I get to make a mess with paint stripper again.
Posted on: 2011/5/20 14:04
You can get a 25 lb. bucket of glass beads for $25, if they would let you change it out (easy to do.
Posted on: 2011/5/20 14:45
High Point, NC
1440 Posts
I will check tonight when I go down to see what they have loaded in the machine.
Posted on: 2011/5/20 16:21
High Point, NC
1440 Posts
I missed your post, Sorry.
I found a guy near me that is building me a 355 from a 91 Vette block. I have an LT$ hotcam that he is going to install too.
Posted on: 2011/5/23 14:14
High Point, NC
1440 Posts
The blast cabinet at mom's job is loaded with ceramic media that they use to texture aluminum. Don't think that I want to go that route. Time for some paint stripper. YAH!
Posted on: 2011/5/23 14:15
If you haven't done it before, make sure the stripper is safe for alum.
Aircraft Stripper can usually be found around town.
Posted on: 2011/5/23 14:30
High Point, NC
1440 Posts
I have a can of spray on stripper that I used to get the paint off my stock runners. I think there's still some left. It did a decent job.
Posted on: 2011/5/23 14:35
High Point, NC
1440 Posts
I think I'm going to have to make my own gaskets on these.
Only because of the plenum to runner connection.
jpg  mrg-146_w.jpg (16.25 KB)
2852_4dda9c84f1832.jpg 400X400 px
Posted on: 2011/5/23 17:42
High Point, NC
1440 Posts
Got one runner and the plenum stripped last night then I ran out of paint stripper.
I started sanding down the plenum for polishing..Deja Vu because I just did the same thing to my original plenum.
Posted on: 2011/5/27 11:32
